Pitty the place is a shit hole. no water, no power, toilets 2km away, no showers, poor PA system. if it wasnt for good company last time i would never consider camping there again.
For sure!! The people at WB are awesome and nothing is too much trouble.
  • Replies 218
No water- yeah its called a drought
Id put up with all the things you listed at WB anyday over the sht way WSID is run.
WSID is the only track we refused to tow to when I had my dragster and I will never ever go there to race or spectate-would rather burn my money than spend it there.
As for more peolpe getting involved from these forums and else where-well thats not going to happen with the current state of play with import drag racing at the moment-I think the scene will struggle to hold onto some current long term members, let alone attrached new ones :(
Edited by gtr660hp
I cant wait for Jambo and if SRWD doesnt have any AWD or 4WD then I have a better chance of being top qualifier.... :/
Adrian,
your not going to make the trip up just because you wont get any points towards your championship?
When we were there in September last year there was a shit load of water!!! Almost 2 inches through the whole venue!!
Adrian
Thats an understatement to say the least....i reckon there was at least 6 inches in the corner of my tent.....water that is...lol
the rule book is out mother fuggers
AWD have there own class, looks like a tussle between the big heav cressida and the light weight 13b mx5 for top qualfier, unless calros comes out int he millenium supra, then we have no chance, 10.04 at 150 mph last year witha 2.3 sixty foot. theres a high 8 in that car
hahahaha you make it sound like your at a disadvantage..... I probably wont get a chance to practice before the event as my axles are 3 weeks away :ninja:
10.04 @ 150mph is pretty impressive.... I dont think my car has a chance going that mph.
Whats the link for the rule book.... I was at the site but it didnt appear to be downloadable...
No trans brake is ok, I havent got mine sorted out yet anyway.
Running alcohol wont affect me either. I might see if I can afford to buy some C16 for the event and up the boost.
Any other exciting changes?
Adrian,
are you going to enter this series?
no aftermarket transmissions
so no powerglides, c4's no supra gearbox behind rotary etc.
if it wasnt an option from the manufacturer its not allowed.
thats interesting and will certainly limit the class.
unless carlos shows up with his manul box in, he wont bein our class.
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
