It is true ethanol is highly corrosive but only in concentrations way beyond what the fuel will contain. Out of all the coatings we manufacture we can't give any warrenty on fuel tank linings for anything with over 50% ethanol as it will just degrade organics. Ethanol does behave differently when solvated in other hydrophobic solvents (fuel) so it's a fairly good bet the fuel system will be fine.
im curious as to how ethanol, a polar molecule is dissolved in a non-polar substance like pump fuel, which is a hydrocarbon ?
Ask petroleum engineer, obviously they manage it somehow.
:D cheers :dry:
>_< cheers :D
Will an industrial chemist suffice? :)
Ethanol has a polar OH group, but also has an ethylene (alkane non-polar) chain attached. It's this alkane chain that allows the ethanol to become miscible with the fuel. Methanol will not blend as it doesn't have a big enough non-polar group....each CH group you add to an alcohol gives it a more non-polar nature...Octanol is fairly non-polar and will not actually mix with water...you have propanol and butanol which sit between.
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
