Ok..
got the clutch for a few months now..but haven't been driving much 'cos i catch the freaking tram to work (CBD no parking) the most boring part of my day!!!.
anyway.. i am sort of glad that most of you reckon the clutch fews soft..which kinda rule out the malfunction question.
I went back to the guys that fitted it, they adjusted the clutch, got a bit harder but still very light..
changing gear is getting very hard, especially 2nd.. have to wait for the rev to drop all the way down before i can hit 2nd..it fews like the clutch does disengage properly..
i put in redline oil like what most of you guys here says one should do..but gear change is still shite!..
the people that put the clutch in..have no idea why..aparently master cylinder is still good..
internal problems?
what does the spigot bush do? because they didn't change that.. could that be the problem..
can you guy recommend a good gearbox specialist..?
spigot bearing wouldnt affect it...i left my old one in and its all good. They may have adjusted the clutch in someway that your not getting the full stroke outta the pedal inorder to fully disengage the clutch...or your lines may need bleeding if for whatever reason they removed the lines from the slave cylinder. If they did bleed it then they may have missed the intermediate valve thats half way between the master cylinder and the slave cylinder, its on that block mounted on the chassis rail. It may only be half bled and once again not letting you get the full travel to fully disengage the clutch.
oh yeh also, the spigot bush/bearing supports the end of the input shaft from the gearbox in the ass of the crankshaft.
There is a few thoughts for ya to check.
Edited by r33_racer
Thanks Dude,
will bleed the clutch this weekend to try to fix the problem..
another problem though..how do i bleed the thing..
I guess another hour on SAU looking for the how-to post..
hopefully that will fix it..because i gearbox is giving me the shite at the moment..
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
