I got my first 97 R33 GTS-T yesterday had no problems,
Today i drove to work at 6:30am didnt push the car at all changed gears at 2500rmp
Arrived at work at 6:50 let the turbo timer do its thing for about a min or so.
Went to leave work at 4:00pm all the boys came and had a look and a chat, turned it on and it was all good, then stood around chatting for about 15-20mins while it idled finishing up conversation. Didnt give it that much on the way home.
Got in my driveway and the turned off the car the turbo timer took over went to get out of the car and i forgot to put it in Neutral took my foot off the clutch and she stalled. So i left it.
Had to go out about 15 mins later and the car wont start, left it for another 15mins and still wont start. Now im getting really freaked out!!! WHats wrong!!! have i f**ked something cus i didnt let it cool down.
https://www.sau.com.au/forums/topic/122242-whats-wrong-with-my-cars/
doubt it, usually turbo timer is only there if u shut it down hot (like if ur giving it to it for the run home) but u didnt, so i doubt that would be the issue. i dunno about damaging turbos and if they owuld stop the car starting? what happens when u try to start it? does it crank or nothing at all?
It starts to crank but just doesnt have the power to really turn it fully over? Could it possible be a flat battery?
The car has only just been imported so im presuming that since i got it, it hasnt been driven for a while? Could it be??? Just seems strange that it worked before.
It has also has been stalling easyly when the car has been just started and been running ritch and backfireing when i drive it really hard, could this have anything to do with it?
I just looked at the battery and theres no calcium build up, all electrics work and headlights work but there not as bright as if the car was on.
Theres no black soot, but they prob washed it when it was in the showroom, and then washed it before i took delivery.
I honestly couldnt tell you about the ECU...
Yeah ill check the relays
Nar i didnt leave the lights on, i drove it to work, drove home later that arvo, then it wouldnt start later that arvo when i had to go out.
Weird. But i only got the car yesterday and before that been sitting in a showroom and before that on a boat coming from Jap, and driven it a little so the battery is prob f**ked
Yeah, I left my lights on once in my 32. Didn't realize it because the timer was running so it didnt beep to let me know I'd left the lights on.
When I got back to the car and hit the alarm button, it triggered the alarm (thought the battery had been disconnected and went to backup battery). Of course, there was not enough power in it for the override switch to work, and it wailed until I got a jump-start.
You wanna see the mother battery I put in there now :P
Yeah, nothing is worse than a problem that comes and goes...
Yes there is, its called an 80s alfa.
Dude, burn the alfa as a sacrafice to the skyline. It will be all better then. You just need the alfa out of your system.
    • It wasn't about the dollars. I mean how she didn't like the loud exhaust and you had to change it again 😛
    • I'll tell her I put in a new air filter on it, which, it would have anyway with the ITB's In the end she isn't to fussed, she spends lots of money on hair, nails, make-up and all the other "required" beauty products that women use, plus I grease the wheels with shiny gifts and holidays wherever and whenever I can She once questioned my car spending "budget", but after itemising everything she spends on herself, and what I spend on her, and the fact that I don't care if she does or doesn't wear make-up and fancy pants perfume, or requires new outfits for every wedding, funeral or anything else she deems worthy, and I'm quite happy to go "real" camping, instead of staying in hotels or jaunts on cruise ships, she decided not to press the subject on how I spend funds, and has never asked "how much did that cost" again, so a win to me And how often can you say you really get a win with the fairer sex? She is a good woman, and in the big picture, I'm really lucky.....that she hasn't killed me yet
    • What will you do when the Minister of War and Finance says the intake noises are too loud?
    • Will the clear coat dissolve the ink tho?? I thought about clear vinyl tape too. Thinking what to do haha. The one I have now is cracked in 1 spot, otherwise mint. Plus the MINES one is much thicker plastic material so its not flimsy at all.
    • No. Go a different colour, and just trim it at an edge line. Even manufacturers do different panels different colours etc.
