Hey Guys, I am having an issue with my Oil Gauge and just wanted some thoughts / suggestions.
I have put in a new cluster because I screwed my old one up by pulling off the needles. :D
After putting it in I check and everything looked to be OK (Oil pressue reads just below 4 - half way) but after looking down last night and seeing it sitting just about 0, I thought oh crap (but everything was running perfectly!!) I checked it out when I got home and there are no leaks and the oil level is fine.
I started it up this morning and up to 4 it went, all looked good and took off for work. 10-20k's later I look down with it in mind and it is once again around 0... hmmm, about 5 mins later it is back near 4! (This is making me think that it is a dodgy gauge because I am guessing I would notice a difference between the two pressure levels - am I right??) Pretty much the same deal on the way home!
I have just replaced the turbo with an R34 turbo and have done the timing belt / water pump...
I am putting it down to a dodgy gauge however I thought it would be a good idea to post to make sure it is not something obvious / severly wrong!!!
Any suggestions or advice would be MUCH appreciated!
Thanks, Todd
https://www.sau.com.au/forums/topic/122256-oil-gauge-reading-just-above-0/
This is what I just put in another post similar to your problem....
BTW it was the countersunk screws in the back of the oil pump had come loose - go figure??
Had EXACTLY this problem - drove it around for 6 mths as oil pressure and noise came and went and still made good power, BUT, it cost me.
Big ends 3&5 (i think had burnt to a crisp -totaly stuffed and crank scoured also so RODS & CRANK needed to be replaced.
Worse it was a AWD ( GTS4) RB20DET so harder to find.
Blind_Elk came to the rescue with his orig RB20DET as he put a Stagea RB25 AWD in his GTS4.
Turbine, Glenn, pulled the crank and rods from his motor and fitted to mine as my block and pistons were much better and less rego hassels.
Will be putting the rebuilt motor back in this weekend with luck :D
Get someone to check your oil pressure with a decent gauge.
It's quite common for the factory gauge to read like that.
It is usually the oil pressure sender on the motor at fault rather than the gauge itself but as you've been playing with the gauge it seems like a bit of a coincidence that it would be another problem.
I think it might just be the gauge or the sender unit. Keep an eye on it when driving. Mine sits abit under the halfway mark, then suddenly drops straight to 0.. car runs fine and had it serviced last week.
Think my problem is related to the gauge. I'll be going for some aftermarket gauges soon so we will know then!
Get a mechanic to put a master guage on it or put a mechanical guage on it yourself. if pressures are good look at the electrics. Should not see less than 20psi at idle at operating temp and should climb when the rpm increases. will peak at around 65psi. these pressures might vary slightly depending on what grade oil you are running.
Thanks, Todd
I have this exact same issue....
I have always ignored it, knowing that oil pressure senders/gauges tend to be faulty and scare the shit out of their owners...............
But now I'm scared.. I might just go and check out the oil pressure next week.
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!ย  We are a pack of know it alls....ย  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!ย  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree! ย
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc. ย  It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things. ย  Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing" ย  As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things. ย  It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first. ย  There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one. ย  However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long timeย  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
ร—
ร—
