How many people bring their GF's/BF's To cruises?
  • Replies 48
I took my girlfriend to one of the TNS pizza runs 2 the Northern Beaches. It was her 1st cruise and she enjoyed herself.
Shes a vegetarian so she doesnt come out to the steak nights:D
Most cruises have a mixed group of people and everyone usually has fun .
anyone else's gf complain about induction noise? or is it just me? he he and i just fitted up some teins - should be interesting to get her thoughts on the 'harshness' of the ride now :D
hmmm, but yeah, generally, unless shes really into cars, cruising etc, i think its better for all concerned if she gives it a miss - its not wat she likes, so y force her?
  Quote
Originally posted by cereal
There's no question as to who wore the pants in that relationship.....:D :D :)
hehe well considering he's now an ex....that would be me ;)
(although I mostly wear skirts lol)
Now all i need is a guy who's into cars as much as me and I'll be happy :D
my gf came to a couple... and she found them boring.. and most of the time ive gotta leave early because of that..
she wont come to the TWS akira meets on saturdays anymore cos it's a "guy thing" and cruises.. she thinks they're a waste of time...
im trying to go alone..but i dont know if its possible!~ she still persists to come, then say it's boring and wants to leave
  Quote
Shell: Now all i need is a guy who's into cars as much as me and I'll be happy
You can take me anytime Shell....:uh-huh:
Its not that I like your car, its more the fact that your legs look soooooooo good in them skirts when you push the clutch in.:drooling:
  Quote
Originally posted by shruggz
i couldnt date a girl with a better car than me.. i'd be too interested in her car... and be jealous every time she kicked my arse off the line...
but then again, you could get cheaper mods for buying in bulk....
Same...but then again.. i'd be driving her car all the time.. :D
  Quote
Originally posted by Duncan
Kelly always drags me along to cruises and track days :)
just tell her Duncan!!...put your foot down and say "Kel, this weekend, we're going shopping" :uh-huh:
QIK78U, you were sposed to be checking out all the skylines, not my legs!! ;)
  Quote
Originally posted by MissS13
Sure Rhys, I think you'd look good in a skirt ;)
Who do we team you up with though.... ????
MINH!!!!!!!!
he'd look rather sexy in a skirt and tight white shirt..
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
