Apexi Afc
I will try and explain this as thoroughly as possible cause it is a little hard if you haven't experienced the problem yourselves. I had an apexi AFC installed and tuned about a year ago. From the dyno tune, the power which was produced was 250 hp (roughly 160 kw). That was with a boost control, intercooler, greddy bov, turbo back exhaust installed. Bearing in mind, it was boost was only adjusted at 8psi.
Now, recently I have had a problem driving on freeways at approximately 100km when the car starts to kind of stop start. It feels like the something is pulling it back and only last a couple of seconds and then will happen again at the same speed. I previously had a service and the guy who serviced my car adjusted the fuel cut defender on the apexi and that seemed to be ok but over 100km, it still gives me the pits. I rang up a dyno tune guy (another one, not the one that tuned my car) and told them and they said that the apexi afc is not really compatible with the skyline r33 95 model's standard computer and suggested I remove the apexi and boost control to make it more efficient. Now that doesn't seem right considering many posts on this forum tend to express how great the afc is. I don't want to bring it back to the original guy because it is too far and I really don't have time but I am not too sure what the other one is talking about either so does anyone have any ideas?
Does anyone have this problem with their car underperforming?
I've got an SAFC2 and its on 93 R33 with no problems.
I'm just taking a wild guess but it may have something to do with fueling. As in, is the flow of fuel. Maybe the fuel pumps shitting itself?
I'm taking a stab in the dark but i would want a 2nd and 3rd oppinion from dudes who work exclusively on imports before you do anything to the SAFC.
Oh and lastely, has anyone ever messed with the AFC itself? Could be messing with your tune if they've messed around with it.
No messing around, not that I am aware of. I really do think it just needs to be re-tuned and also the fuel pump just can't handle it....will need to check that out. Thanks for the advice.
check the other thread on the same subject in the 'forced induction' section. its titled something along the lines of 'Mysterious power FC missfire'
the power FC is known to 'cut out' for a brief micro second while cruising.
Edited by SLIPPERY
yo, ure using a afc right?
I reckon its the fuel pump not running right atm. Maybe its been tuned to run well and effiecient at the lower rev ranges but up high its leaning out.
Wat happens when u stretch the gears ou and ay given speed? Does it still shudder?
If yes, i'd say it def a fuel issue. Get an import mechanic to take it for a drive, they'll figure it out in now time.
good luck mate
Hi, I really can't understand how it could be the fuel pump. At 100kph my car used to (with stock injectors) run at 6 to 7% injector duty cycle. Not a lot of work for the fuel pump I would think. I did also have AFM problems but was flat out getting to 40kph and 2500rpm. Which is about the stock ecu limp mode.
i had a similiar problem with my car a lil while back and when i upgraded the fuel pump it sorted itself out.
I'm no expert when it comes to cars, just throwing out some suggestions to look at.
i have the exact same problem with mine at the moment. have u turned up the boost by any chance? im pretty sure its fuel cut in my opinion not the fuel pump but the fuel pump can contribute if running higher boost. if u turn your boost rite down to around stock psi and give it a run on the highway and see if it still does it. i just put in a SAFC2 and its getting dynoed very soon, so that should fix the prob for me. another option is to go out and spend heaps on a power fc, or a mines ecu which is way cheaper and it has fuel cut defender built in along with a few other goodies. or u could get a fuel cut defender and have it tuned by someone who knows what they are doing.
its so obvious too. the guy adjusted your fuel cut defender when it last got serviced. theres the answer. i suggest going to another person who really knows how to specifically tune your car/afc.
well thats my opinion anyway, feel free to correct me if im wrong because i am no expert at this. i hope u fix the problem soon. good luck
Its obviously not high boost related. If you actually read her post you would have read that its only on 8psi.
And why would she be on full boost doing 100km's on a highway anyways? If she's cruising at 100km's and its doing it what does boost have to do with any of it.
have you checked for dirty injectors at all?
Hello,
Not that iam a expert at these things...but
Alot of things can do this to you, faulty coils,faulty injectors,faulty fuel pump or regulator,
even the AFM if faulty.The problem is at that speed, something is not working right
Suggest you get it checked by someone who knows what there doing,then you have someone to blame...
Good luck
Edited by 700HP-GTR33
 Share
    • Suspension bush. Got urethane bushes in the upper arms?
    • thanks for heads up on actuators - will sort something as back up or solution as yes dont need that have enough trouble but no doubt some addition of something to spares boxes is required yes have a clue about WTAC but nothing has been officially put out yet so will wait to see exact details Pro class is, has been and will become a draw card for lap records and one off builds for show and thats about it I think - be interesting to see how open they make it Pro am is the old Pro in reality Open class will be split into 2 with slicks and 050's with no doubt slight variances in allowable drivers and changes in aero Clubsprint + apparently a true street class   They have to and are refreshing it all and bringing things up to current standards and need to 100% adhere to rules because whether people like it or not / or say it or not - for alot of competitors it is sheep stations and has been for a while when Im getting told I was illegal because i cut my rear bumper too high and yet others where in the grey areas of legality with everything from engines, suspension, ride heights and more serious influences it actually got quite out of control and heated this year so as much as I may be impacted by some of the changes and prob spit the dummy when I have to spend money changing things I think its a good thing for all
    • I can’t tell if it’s suspension related or maybe wheel bearing or motor mount.  IMG_6209.MOV
    • Start with a multimeter, and see if you're getting power at the TPS. There should be a manual for your car somewhere on these forums and it'll have the info for what closed TPS signal voltage is, and how it should sweep to full throttle. Same as for other sensors / valves.   Have you checked things like your base timing etc? See if anything looks amiss there too?
    • here are 2x options to consider: https://www.selby.com.au/price-promise/tonewinner-sw-d6000-subwoofer.html https://www.apollohifi.com.au/svs-pb-3000-ported-subwoofer-black-ash-pre-order.html I'm waiting for a good BF/CM sale and will pull the trigger on a new sub, I do like the SVS PB-3000 (13") but you could nearly buy 2x Tonewinner D6000s (15")
