Hey All,
Just wondering what dump pipes and front pipes you all have?
As some of you know i just got my stagea on sunday, it already has a fujitsubo cat back system but i want a stainless dump and front pipe. But im not sure if R33 Skyline dumps and fronts fit without modification.
Or am i better off getting a custom dump and front made through an exhaust shop over an off the shelf item.
Thanks for all the responses in advance
Simon
https://www.sau.com.au/forums/topic/122282-stagea-exhausts/
  • Replies 67
Posted Images
I'm pretty sure Alex has the split BOSimporting one.
I've got a custom made one l bought off a guy who owned an r33 ... haven't had a chance to fit it up yet though.
And we'll have to catch up soon ... def time for another stagea meet with all these new Stag's about!! :P
https://www.sau.com.au/forums/topic/122282-stagea-exhausts/#findComment-2257778
I am currently modifying mine and adding a split front/dump pipe all the way back to the new magic cat. And as the turbo housing needs to be modified as well to make the split wastegate effective, I used my mates which he had already moded - it was a from an R33 and bolted straight on. The turbo needs to be completely removed to do this.
From what I have read on other threads, unless the split is a couple of feet in length it is a 'waste' of time (no pun intended). However the first foot of the dump pipe is the hardest to manufacture (if you're doing it on your own) so buying an off the shelf item and then chopping off the back end and extending it further along to the cat can be as easier way to go.
My costs so far:
Moded turbo housing - free
Turbo flange with split wastegate - $35
Magic Cat $300
3 inch 2 bolt flange - $15
Mild steel 3 inch pipe - free
1.25 inch wastgate pipe, pre bent from exhaust shop - $35
O2 sensor nut - free, you need 18mm ID X 1.25mm thread
An off the shelf split dump pipe is going to cost $150-200 then you still need to cut and extend it (unless you get one that is already the right length) Plus you'll need a larger cat or you're wasting your time by leaving a hefty flow restriction in the system. IMO stainless is just for show unless you're keeping the car for more then ten years. Or unless you intend to heat wrap the dumps.
Edited by 3intheBack
https://www.sau.com.au/forums/topic/122282-stagea-exhausts/#findComment-2258016
BATMBL is the man, stainless or mild steel. Send him a PM, he has them in stock. BTW $300 for the Magic 4" cat was a lot, they were $210 on the Group Buy.
Tip, when looking for stuff try the Group Buy section first, good prices and always plenty of reports back from other SAU guys.
:blink: cheers :)
https://www.sau.com.au/forums/topic/122282-stagea-exhausts/#findComment-2258107
I'm running a split dump made up to suit r33's from Advan. is stainless steel,cost me $350,and needed a 1/2" thick spacer to mate up to the cat properly,as it's shorter than the std dump.
Justin...
Edited by fergo308
https://www.sau.com.au/forums/topic/122282-stagea-exhausts/#findComment-2258341
:D cheers :D
I agree and I told/ask them about matching the group buy and they wouldnt be in it.
Usual deal...wanted it in a hurry to complete the job, so I paid up, then didnt finish it before the skidpan day so now the car has a modified turbo housing connected to the std front/dump - sounds like its passing wind all the time.
https://www.sau.com.au/forums/topic/122282-stagea-exhausts/#findComment-2260221
Yes i just pm`d BATMBL earlier and he was more than helpful.
Just gotta get a couple of other things done to the car this weekend and then in about 2 weeks i will order the dump, front and cat!
Cheers for all the help too guys
https://www.sau.com.au/forums/topic/122282-stagea-exhausts/#findComment-2260984
hhhmmm all too hard.....
this is what I bought:
a BATMBL 3inch hiflow cat converter, bolted that on to mate onto the 3inch cat-back exhaust system that was already on the car.
then I went off to ebay, and bought, for roughly $220 delivered, a Just Jap stainless steel 3inch dump pipe (from turbo to catconverter). easy, for an R33 gtst, no hassles, installed by mechanics when I had other stuff tuned. Mind you, thinking about it, Im sure they machined down the edge that mates to the turbo, and added a spot weld and threw in a gasket - like under $100 to install it. Quality was good, not 100% perfect, but definately useable and a good price I thought. Does the job!
Anyway, that makes it cheap and easy. why pay $300 more for a split system??? I dont get it, unless you are chasing maximum HP
Edited by Tangles
https://www.sau.com.au/forums/topic/122282-stagea-exhausts/#findComment-2262205
My thinking,
The split flows better with reduces turbulence generated by the 2 outlets when the waste gate is opened, this would be a benefit on a standard engine/turbo/boost set up the same as it would be on a modified set up. You wouldn't say "I want 150 awkw" and stick with a standard exhaust system, winding up the boost and supporting mods until you got to that power level, so why not use a split dump/front that flows better than a single front pipe?
Just my angle, I don't think you would go from what you have to a split now Brendan but maybe from standard this is a better option?
Interested to know why it doesn't fit the High Flow, has to have something to do with the exhaust housing being machined and the pipe no longer matching that size I guess...
Chasing maximum benefit!
Cheers
Luke
https://www.sau.com.au/forums/topic/122282-stagea-exhausts/#findComment-2262328
Be careful with the SS front/dump pipe, it will only suit a standard turbo, not a highflowed one, i came across that problem.
Could you please explain? i've just gotten myself a hi-flo, and i thought they used the exact same turbo housing as the standard turbo. why would this mean any standard dump pipe wouldn't work? i've got a custom mild steel dump, nothing flash but i just don't want to have to fork out for mods to my exhaust if this turbo is different
https://www.sau.com.au/forums/topic/122282-stagea-exhausts/#findComment-2262581
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
