  • Replies 67
Posted Images
Wolverine: yeah,they use an afm to control mixtures. on the neos though,there's a map sensor that's there to monitor boost,and the ecu then triggers the cut at the level I mentioned earlier,as reported by my the peak hold on my digital boost gauge. if Sk can sucessfully dispute this,great,maybe I'll learn something.
Alex: if the cut is actually the AFM hitting 5v,how do you guys with larger turbos handle the problem? are you running Z32 AFMs? guys with far more power than my car makes have been running the std AFM for a long time and still have plenty of resolution left in their airflow maps.
I've felt an AFM 5v cut out before on an S14 I owned a while back,and it's way more savage than what the neo does at EXACTLY 1.0kg/cm3 of boost.
it's a limiter in the ecu. anyone who doubts this is welcome to meet me somewhere and experience it for themselves.
Justin...
It is not the AFM maxing out but its the AFM registering an AF that is too high for a specific rpm/load.
THis is based on the std tune which is given.
What a DFA/SAFC does is "bends" the AFM voltage to trick the ecu in thinking there is a lower air flow than there is (this is OK as the std mapping runs rich anyway). So there is a certain % gain you can have with an AFM bender. Basically, these electronic units are variable resistors with multiple load points
Justin...
A quick explanation on “boost cut” and R34’s / Stagea S2’s;
1 The ECU cuts NOTHING, fuel still flows and the ignition still fires, so calling it a “CUT” is 100% wrong.
2. The R34/S2 ECU is a bit smarter than the previous versions, but like them, it still has Rich and Retard mapping that it reverts to when it detects something amiss. For example if the throttle position and the rpm don’t agree with the AFM voltage the ECU hops into R&R mapping.
3. The ECU doesn’t care about boost. If you fit an SAFC/DFA (or equivalent) you don’t get R&R mapping. If the ECU cared about boost then fitting an AFM voltage bender wouldn’t work
4. Combining #2 and #3 above, you use an AFM voltage bender to realign the AFM voltage with the throttle and rpm. So the ECU thinks that all is well and doesn’t get into R&R mapping.
I hope that clears up the fallacy of boost cut and Skylines/Stageas.
:D cheers :dry:
fair enough. so.....what's the MAP sensor there for? purely for the optional gauges that aren't an option on the stagea?
while we're talking the whole panic mode thing in the ecu,I've seen that before as well,at about half as much boost as I currently run,as I had too much base advance dialled in at the CAS (thanks CRD...). if it detects pinging,it winds the boost and timing back,and goes rich,as you've described.
that isn't what happens at 1.0kg. it CUTS.
like I said,you're more than welcome to experience it for yourself,and then talk to me about it.
Peter at Advan refers to it as a boost cut,and was adamant about why it's there,and why they don't run a std turbo above it.
I may be a newbie to you guys,but I've been around cars (nissans and otherwise) for quite a while now,and actually know a thing or two. being that I'm also a qualified mechanic,I reckon there's a chance that I have at least half an idea about what I'm saying.
if I'm not sure of something,I'll say so.
if I say it's a cut,there's a VERY good chance that's what it is.
anyway,the offer is there mate,and I'd actually not mind your input.
I'll be putting my car on the rollers on sunday. if you want to meet up and have a chat about this,pm me,and i'll let you know where I'll be.
Justin...
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
