Here's translation from Russian of the article originally written by A.V. Perunov from www.auto.vl.ru Original address of the Russian version is http://enc.auto.vl.ru/6421/
To replace old spare plugs on Neo series Engines (RB20DE or RB25DE or similar that were installed on R34 Skylines and some other vehicles (Stagea, Laurel) you will need: wrenches, screwdrivers, pliers plus a hex-nut wrench.
First of all, you should remove the plastic cover that carries Neo6 label and see the following:
LARGER PICTURE IS HERE
Now, the part noted as "1" in the circle - is our aim - that cover hides coils and spark plugs.
Firstly remove nipple 1 by disconnecting clips on both sides of it with pliers.
Then disconnect nipples 2 and 3 at the sides indicated by arrows. Important note here - the engine should be cool as these nipples are part of cooling system and if you disconnect them on a warm engine, some amount of cooling fluid may spill. It's better to open the radiator cap before disconnecting the nipples too to alter the pressure.
Disconnect connectors marked 4 (you may want to remember them by colors, however, it's rather difficult to confuse them).
Disconnect clamp 5 and onscrew bolt 6 - now you can move airduct apart in the direction of green arrow.
Diconnect nipples 7 and 8 and two nipples marked 9 - remember that one of them that is closer to firewall has a clamp.
Disconnect two sockets marked 10. Thay are different colors.
Now, disconnect two more sockets marked 11 on the following two pictures (note that firewall is on the left side of those pictures:
Be careful not to brake them - they should be disconnected in the directions marked by arrows. There is no need to remove the metal part that holds the sockeit in place - it will be later removed together with cover. The sign "!" indicates the place where the wire should be disconnected from the cover.
Unscrew 6 bolts holding the intake manifold in place (marked 12 on the first picture). Remove manifold carefully in order not to damage the gasket.
Put the manifold to the left side. Now it's time to remove the cover. Here you will need a hex-wrench. After unscrewing all bolts holding the cover, move it towards the firewall a bit and then take out.
After that, you should see something like this - we're almost there =)
Unscrew bolts holding coils in their places, disconnect coils from the wire and - here we are - time to use the spark-plug wrench =)
After changing plugs check coils as described here http://www.skylineowners.com/forum/showthread.php?t=43555 and assemble everything back.
The whole procedure takes about one hour and a half or so.
P.S. Me personally didn't do this yet, going to try on Sunday - perhaps after that there will be some minor changes from my own.
P.P.S. My technical English is not very good - if you have some corrections regarding the terms - please tell me.
P.P.P.S. Neither me nor original author bears any responsibility for any concequencies of following the proceduredescribed above. This is for informational purposes only. Whatever you do, do it at your own risk.
  • Like 1
  • 1 year later...
Was wondering why pics didn't looking anything like my engine bay! Title refers to N/A as opposed to 25GTT :D
There is a great tute around for changing coil packs on a GTT;
http://www.skylinesaustralia.com/forums/Di...tml&hl=coil
Pretty much exactly the same steps reqd for changing the plugs - bit of compressed air in a can was handy to blast away the dust/gunk/crap before putting new plugs in. Don't overtighten the plugs and it's pretty straightforward. I used copper plugs gapped to .8mm and solved all my missing when coming on boost issues.
One tip - which sounds a bit odd, but may help someone - before taking off the coil pack cover take off the oil cap. Otherwise it is super tight to get the cover out.
Hope this helps.
  • 1 year later...
An accurate guide to replacing R34 Skyline spark plugs.
Will take 1.5 - 2 hours.
No need to have a spare Intake Manifold Gasket - is metalized and sealer not used, so it comes away cleanly.
Overall level of job difficulty - low.
I found it easier to completely remove the Intake Manifold. Will need to remove the Strut Brace to achieve this.
_____________________________
Edited by Les00x
  • 4 months later...
nb: stock RB 25 DET NEO uses BCPR6ES - 11 (1.1mm gap)
I've got the same but have been recommended to gap them down to 0.8 mm on stock engine and boost (R34 GTT) as I still have the original coil packs that are getting a bit tired.
I've also been told not to bother with platinums (had NGK PFR6A-11's on the car previously) but just keep using copper ones correctly gapped.
More spark plug discussion here
  • 4 weeks later...
  • 11 months later...
Just to put it out there the spark plug gap for my nissan r34 rb25det neo says it should be 1.05 mm. This according to the service sticker on my airbox. =S
I haven't started yet, but i'am going to change my spark plugs soon and will inform you if mine are in fact 1.05mm.
  • 1 month later...
great post mate, wish i saw this before i was charged 450 for a set of 2nd hand coils and copper sparkies + labour :(
3 different mechanics in perth told me changing spark plugs on 34's was a big job so i let them do the work
  • 4 years later...
Anyone know what plugs are recommended for a RB25DE NEO? just need basic ones I guess i've seen so many different responses to what one to use so i'm not sure anymore
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
