As my brake pads have worn out, it's now time to get a new set. I've done a search on the forum and could not exactly find what I am looking for. I don't need those that will stick your nose to the windscreen once you slam the brake as I am quite happy with the stock Nissan ones. However, if I can get a better ones would be great, as long as the price is OK... prefer not to spend over $130 a pair.
I heard that Bendix Ultimate are pretty decent and would probably meet my criteria, but I heard that they are very dusty. How much better is the Ultimate compared to the Advance (basic ones)? I also heard Hawk and RB (Racing Brake) are pretty decent brands, but don't know where I can get them from.
Your recommendations are much appreciated! Would be good if you could include the price and place where I can get them from in Sydney
Cheers,
DD
https://www.sau.com.au/forums/topic/122287-brake-pads-for-r33gtst/
Bendix Ultimates are ok for street but I'd go with Ferodo DS2500's
You can get the Ferodo's from V Sport.
The Bendix Part numbers (which most other companies can cross reference with) for the pads are: DB1170 for the front and DB1220 for the rear.
Cheers,
DD
Race Brakes Sydney at Wetherill Park can supply all the brands you mentioned 02 9609 1101.
What's the deal with Ferodo brake pads? Heard a good wrap about the DS2500 series, but went to the website (http://www.ferodomotorsports.com/main.htm) and they only have the excel, formula, premier, GP2 and 4WD series.... Does this DS2500 series actually exist?
Also, is it OK to run different set of brake pads / rotors on front and rear? Thinking of getting slotted rotors with decent brake pads for the front, but leave the rear as is (stock)... is this a reasonable approach or just plain dangerous?
Thanks
DD
Thanks
DD
I've done that mate, have Slotted rotors on the front and stockies on the rear as fronts needed replacing anyway. Works a treat, i asked the same question before i did it and everyone said it was fine to do.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
