I saw a post about tyre pressure the other day and it remided me to go and get nitrogen put in my tyres.
I had it done at Bob Jane..it cost $20..I have had it in my cars before.There are a few benifits to be had by using Nitrogen rather than standard old air. Nitrogen is a denser gas.You dont need to check your pressure as it remains constant as it is not as affected by temp changes.Being more dense it may give slighly better ride and handleing ..... to me..the car feels more solid with the Nitrogen but not hard like it does if you put a lot of pressure in with air....with any luck it will help with fuel economy cos thats the only thing that I dont like about my Stagea...anyway if you dont change your pressures much you may want to give it a try...oh yeh having nitrogen in the tyres also seems to stop the tyes from flatening on the bottoms which tends to happen if you dont drive the car a lot.
Scott.
One more thing.. cos I know somone will ask..yes you can mix air with the nitrogen if you need to.
https://www.sau.com.au/forums/topic/122362-nitrogen-in-my-tyres/
I think the benefits are largely inconclusive for regular street driven cars, nothing that regular maintenance and checking with compressed air can't prevent. Compressed air is about 80% nitrogen anyway.
http://www.toyo.com.au/tech_info11.html
http://www.bridgestone.com.au/tyres/produc...re/nitrogen.asp
http://www.racq.com.au/cps/rde/xchg/racq_c...es_ENA_HTML.htm
I wouldn't think the benefits would be worth $20.
As you say, nitrogen has less expansion/contraction with temp, but with the small volume in a car tyre, it wouldn't be that noticable.
They use nitrogen in aircraft tyres because they have a much larger volume and it is at a higher pressure. Also air contains oxygen, so if it is used in an aircraft tyre, it can be bad if a brake fire occurs.
If you can get nitrogen for free, go for it. But I wouldn't pay $20 for it. The main advantages of it are lost on road cars.
  • 3 months later...
The usage of nitrogen in tyres on race cars that I have heard of is to allow the use of a cold pressure reading as a starting point to achieve a desired hot running pressure. The pressure of the tyre can vary between 3 and 4 pounds between cold to hot due to the water in the air. This is alluded to in the toyo link above when they talk of `dry air'. Thus the use of nitrogen eliminates this aspect of variation in race preparation so that grey matter can be spent elsewhere.
raz0r was correct, air is made up of ~80% nitrogen anyway. Then there's something like ~18% oxygen and a couple other gases.
So whilst there is a difference, the difference between pure nitrogen and normal air probably isn't as much as it sounds. :P
Compresses air isnt compressed air but is compressed air.
that sure as hell made it as clear as mud. what the? is it supposed to be as follows?
compressed air isn't compressed OXYGEN but is compressed air?
that would make more sense don't ya think?
have used nitrogen in race cars i have worked on for a number of years now. we take a big bottle of it to race meets instead of the compressor. Yes it is a little more stable than air so less pressure change from cold tyre to hot tyre but there is still a change. we even use it in the on board jack system. we find it's small advantage is a slightly more stable tyre pressue over many laps. for $20 a fill I wouldn't bother.
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • Yeah go with that one
    • This one?? In other news: I cannot tell the difference between my red MX5 with the silver grey hard top......... and the Ferrari 599XX EVO, they might as well be twins, well.......apart from the big wang hanging off the back of the Ferrari...🤔🤣, without the wing they are identical
