I saw a post about tyre pressure the other day and it remided me to go and get nitrogen put in my tyres.
I had it done at Bob Jane..it cost $20..I have had it in my cars before.There are a few benifits to be had by using Nitrogen rather than standard old air. Nitrogen is a denser gas.You dont need to check your pressure as it remains constant as it is not as affected by temp changes.Being more dense it may give slighly better ride and handleing ..... to me..the car feels more solid with the Nitrogen but not hard like it does if you put a lot of pressure in with air....with any luck it will help with fuel economy cos thats the only thing that I dont like about my Stagea...anyway if you dont change your pressures much you may want to give it a try...oh yeh having nitrogen in the tyres also seems to stop the tyes from flatening on the bottoms which tends to happen if you dont drive the car a lot.
Scott.
One more thing.. cos I know somone will ask..yes you can mix air with the nitrogen if you need to.
https://www.sau.com.au/forums/topic/122364-nitrogen-in-my-tyres/
hmmm not too sure about that one.
As soon as I read the bit about not needing to check tyre pressures, something didn't sound right, so I went looking for some more info and came across this:
The rubber used for tubes & inner liners in tubeless tyres is not 100% impermeable, therefore some pressure loss can be expected over time. This is one reason why regular pressure checks are necessary. Due to its molecular structure, nitrogen bleeds through the inner liner or tube at a slower rate than regular compressed air. This advantage applies to all tyres filled with nitrogen. Regular pressure checks are still recommended, as tyres often lose pressure due to slow leaks caused by punctures or valve leaks.
Regardless of what you have in your tyres, you should still check the pressure regularly.
Scott.
Mmmm, where to start.
Nitrogen is a denser gas. Um no it isn't. The major constituent of air is nitrogen. The second most common elements if Oxygen. Which is more dense than nitrogen, so...
You don't need to check your pressure as it remains constant as it is not as affected by temp changes.
Sorry, but nitrogen, like any gas held within a constant volume (like air, too) will increase in pressure when heated.
Good salesmen at Bob Janes........
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
