Ok, this is kinda hard to explain, but when i was driving along this arvo my car backed off as if i had taken my foot of the throttle but i didnt move my foot, so i put my foot down more n my car continued to decrease speed. It has done this a couple of times b4 but only for a second or 2, this time i actually had to change down gears!!
The car is a R33 GTS-t with zorst, pod, fmic, standard boost solinoid with "high boost mode". (earthed solinoid). Im also pretty sure the coils need replacing, not sure if this would have anything to do with it???
https://www.sau.com.au/forums/topic/122373-need-help/
Possibly dry solder or poor conection on afm???
https://www.sau.com.au/forums/topic/122373-need-help/#findComment-2260087
direct feed thread here
http://www.skylinesaustralia.com/forums/in...91993&hl=direct
- AFM fix here
http://www.skylinesaustralia.com/forums/in...howtopic=113284
fuel filter here
http://www.skylinesaustralia.com/forums/in...&hl=fuel+filter
try that and let us know
if it doesn't fix it, then atleast you know these thingswont cause you issues in the future
https://www.sau.com.au/forums/topic/122373-need-help/#findComment-2260429
