Hey guys,
The other day I made a cold air induction pipe for my 33 GTST. The actual pipe I bought cost $15 from magnet mart and some cable ties which are like 2cents each.
Here are some pics of the final result..
Works a treat!
atchmnt1
atchmnt2
atchmnt3
-JD
Edited by JD-33
https://www.sau.com.au/forums/topic/122374-15-cold-air-intake/
Awesome man its look good!! cheap as well which is a bonus!!
So im guessin u got a fmic, and dont use stock piping??
Got any tips for ppl who still use stock piping??
i got snorkle anyways, but would love to put more cold air for my pod.. (using mr_crusts heatsheild box for stock snorkle)
yeah man, got a FMIC which frees up a hole below the POD..
will take some pics of the inside when i get a chance.. i forgot :D ..
yeah me and my mate are designing some CID pipe for his car which uses stock IC ..
will let you know how it goes..
Cheers,
-JD
nice one...I have done exactly the same but with the Al pipe. Next seal the pod in a box...if u already havn't done so. As for water issues...had this type of setup for ages on all my cars....never had a problem...some have a BNC filter and others the Unifilter...
the filtering properties of a Unifilter for example has dust retention properties of 4microns (paper is 30 and cotton gause is 45!) however with a large enough service area it has been proven to get roughly 25% less restriction than paper filters...and about restriction as a std K&N cotton gause type.
anyway the conbination of the oil soaked foam and the fact water is much greater size than 4micons means ur pretty safe I reckon...(although I don't know what the actual size of water is but its much greater than air/dust!)
Edited by khunjeng
I've ran a 100mm dia cai which is larger than the one in the pic here.
In 4years maybe slightly more and 150,000km's.. Never had a problem.
People worry too much. :domokun:
I've been though those big aquaplaning puddles that you can't see when driving in really heavy rain.
I checked the filter soon after, it was dry the cai did have a little mist in it.
just for the idiots out there, when you drive through a puddle, unless it is about 6 inches or more deeper, the front bar doesn't touch it. it is you wheels that splash it. the front wheels are behind the front bar, so there is no water splashing into the cai.
I just re-used the elbows and piping from my stock intercooler setup (through the hole that was left after the install). Sits inside the front bar perfectly and didn't cost me anything other than 15minutes of thought and half an hour of installation.
I agree with the "no water" thing, and if you are really unsure, just tilt the CAI so it's always pointed downwards, even if water gets in, it'll just run out again.
for water drainage i have pierced small holes in the underneath and backing of it... (used a pin todo so)
its very secure, ive taken it to 175 and she doesnt move at all, this is because the piping is like a slinkee, and i made it longer than as you see it, so when is in there with the cable ties its applying pressure towards to front of the car and ud towards to cabin..
the pipe has no brand, i just asked for an aluminum pipe which is flexible..
cheers,
-JD
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
