Is it hanging the tail out or are the wheels spinning as if it's a normal rwd car? Check that the attessa is working if it's the second of the 2. Don't forget that GTR's aren't full time 4wd, nothing much happens with the 4wd system until it detects loss of traction etc, so they can be a bit wilder than you may expect with the rear end. Attessa is a reactive system, meaning that it has to sense when it is needed and then kick in so there is a small time delay.
How is the tread on your tyres also? Your problem could be related to a number of things...
Edited by randominsanity73
https://www.sau.com.au/forums/topic/122377-r32-gtr/#findComment-2260280
Is it hanging the tail out or are the wheels spinning as if it's a normal rwd car? Check that the attessa is working if it's the second of the 2. Don't forget that GTR's aren't full time 4wd, nothing much happens with the 4wd system until it detects loss of traction etc, so they can be a bit wilder than you may expect with the rear end. is a reactive system, meaning that it has to sense when it is needed and then kick in so there is a small time delay.
I gotta bradnew tyres.(all 4) i don't know what happen... i think its back wheels spinning faster. what is Attessa?????
https://www.sau.com.au/forums/topic/122377-r32-gtr/#findComment-2260299
Attessa is the name of the 4wd system that all GTR's have. It loads proportionate torque to the front wheels in certain situations such as when it senses wheel spin, level of G-force etc. There are numerous things to check if it is a problem with the attessa. Firstly check that all your fuses are in, as pulling the fuse is a common way for people to get the cars to run in RWD mode.
Is the 4WD light illuminated on the dash?
Could also be related to diffs or hicas if it's not the attessa. There's heaps of things to check with the attessa and if you don't know much about it then it's probably best that you send it to a trusted performance workshop and have them check it out for you.
https://www.sau.com.au/forums/topic/122377-r32-gtr/#findComment-2260322
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
