Hey guys,
A few of us from around Hornsby are meeting up tommorrow night for a bit of a drive.
Meet - Mt Colah Maccas 7:30pm
Heading down Bobbin Head towards St Ives and then onto towards McCarrs Creek Rd - grab a bite to eat and head back.
Wont be a late night, just a bit of a fun drive.
Anyone interested?
See you there!
:D
Chris
https://www.sau.com.au/forums/topic/122378-friday-night-16th-june/
If I'm around / not still at work I'm a maybe
Might take the highway though my car dosen't seem to stick to those roads too well...
Ricky!!!
Thats cool mate - We can wait for you!!
just wait for us though at the end of bobbin head road ok??
:devil:
You know you want to James :ermm:
:thumbsup:
f**k I'm even more pissed off now.....james just made the car the way he wants it and was starting to reall enjoy a good thrashing... makes me so sad!
james if you still wanna come, you can ride with me... it'll be better getting out and getting your mind off it!
It was a pretty nice clean run, for the bits I did make. It was a good night for it - all that cold made for great throttle response.
I don't think I bottomed out through McCarr's Creek Road, which would be a first.
yeah it was a good nite its a pitty more of the sau's dont come on them.
i love our little hornsby cruises... I've got some good mates I usually cruise with.. although haven't for a while... i should call them out one day for a run!
yes Liz, yes you should
Also - I've got a few mates with other cars who are keen, a good mate of mine in a VU SS 50 ute - this thing...well....its blindingly quick and the handling - 2nd to none. another mate with a 500hp 300zx, just to name 2 :)
My new brakes and suspension is going in to the car this week, so if there's another run on this Friday I'm keen, but I'll be taking it at the same pace as last Friday whil I run the coilovers in.
Chris - some of the guys last Friday (your mate from Mudgee at least) has never done the Commenara Parkway. We should rectify that. :) Unfortunately there are houses facing on it, but its a lovely piece of road.
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
