Misc R32 Parts
All of this stuff must go..
R32 auto shifter leaver, etc - $10
R32 manual climate controls in gc - $10
R32 drivers window, has the usual guide scratches (suit cheap temporary replacement) - $10
R32 auto brake pedal - $10
R32 GTS-T accelerator cable in GC - $10
R32 GTS-t bonnet latch and support in trendy black - $10
R32 GTS-T stock fuel pump (pump only) - $20
R32 GTS-T clutch slave cylinder in GC (with temporary actuator pin.. suit replace for leaking one) - $20
R32 aircon box - $10
R32 Heater box and core - $50.. No leaks. Useful for spare.
R32 GTS-T LSD centre.. in good condition and bearings still in good nick. Just needs cleanup - $60
R33 rear springs and shocks (unsure of shock condition, springs look ok - FREE pickup only)
R32 factory seatbelts (japan) - $10
R32 GTS-T non type-m (5 stud) single pot calipers front + lines + rotors - $free
R31 engine loom (from a s3 manual), is minus afm plug - $20
R32 Steering rack - $50 Came from GTS4, not sure whether suits GTS-T or GTR, may well do. No signs of leaking or anything. Useful as a spare
R32 cross member and Urethane bush - $60.
Not really suit street use, as sends a lot of vibration through the chasis. It does however lock your gearbox down rock hard. Would suit dedicated drifter or track car. UAS is selling these mounts or very similar for $195 !
Updated 1/10/06 - Everything needs to go..
Parts are on the Gold Coast, QLD - The larger stuff is pickup only, rest may post.
mate i'll take the radio suround let me know how much postage cost to nowra nsw 2540 please asap and your details how to pay pm or email me [email protected].
also u wouldnt have the rear c pillars would u? it covers the rear window to the rear? let me know
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
well the actual cylinder is fine.. I just rigged up a rod in there for a few weeks which seemed to work. Might do the trick. If you've got a stuffed one, just take out the old rod and use that.. Most of the new cylinders you buy don't have the rod included.
Updated... stuff must go in next 10 days!
 Share
    • There are fixes for this. In industry we use compressed air for everything. It is frequently wet, and many things cannot tolerate it. So there are various forms of driers available that you can install. The simplest option for something like this would be a dessicant drier. Much cheaper to replace some silica gel than actuator cylinders.
    • That's a solid update mate, well done at WA FOS. You may already know this, but the actuators on the paddle shift are a service item and are sadly not that reliable. As I understand it they collect water from the compressor (condensation) which then rusts the bores/pistons in the actuators. A mate of mine had no end of trouble with them in one if his circuit cars, apparently it's a 'known issue'. Buy a couple of spares at great expense to ensure you never have any problems with the ones you've got! Any clues about what the new WTAC rules might be? While faster cars are cool the Pro class arms race has got to the point where you wouldn't even bother entering without a $1m budget and even then I don't think you'd win.
    • https://nissan.epc-data.com/skyline/er34/3945-rb25det/trans/317/31940N/ The pictures of the part you're talking about is clearly not just one solenoid. You can see another picture of it here: https://www.alltranz.com.au/shop/drivetrain/automatic-transmission/RE5R01A/product/9305/ The 4 speed automatic in the GTT is Nissan corporate stuff. You can search up similar jobs done on a Frontier or Pathfinder with a RE4R01B to get an idea for what the internals are going to look like and the procedure like this:
    • Hi Chris,   long time since your post, just wondering if you have the Pinout for the v35 stereo plugs, I bought the roem nis2 harness but it doesn’t match the v35 connector. any help appreciated, I can work out the grn and power constant. But the rest might be hard. thanks Tyson
