  • Replies 53
Posted Images
Nice! I fixed my PFC issue too :( Was a blown fuse. Cant wait to get mine tuned at hittman and see what I get :)
Can I ask what mods you currently have to get what you got? PM me if you dont want to say publicly and Was it a power tune or a complete?
No worries mate my mods are:
1995 RB25DET
Standard Turbo
R34 GTT Intercooler
Adj Exhaust Cam gear (set at 3 1/2 deg ret)
CES 3" split dump pipe
Magic cat
Custom 3" into 2 x 2 1/2" exhaust (very similar to Apexi N1 Dual muffler)
GTR Fuel pump
Apexi Power Intake Pod filter (with custom cold air partition)
NGK Iridium spark plugs
hi ryno
i would be interested in talking more about your tune. max power is only one aspect of an ecu tune. theres lots more to be gained in the midrange and the important parts of a tune
Hey Paul,
I am rather fussy with my car, so I researched tuners for a while before I decided to go to Hitman, and I must say he didn't disappoint.
He spent about the same time tuning the cars economy, as he did max power. In fact the max power was never much of a drama, as the first run (with the standard Power FC maps) made 183 kw. I'm very happy with the tune, the car is now smoother than it has ever been, has more power, and uses less fuel. Perfect!
Ryno
holly s##t my car is doing the exact same thing so you say it was a earth will it be the sams if i run all new earths. sorry to hijack your topic.
Hey mate,
It sounds like a few people have been having this problem - here are the places to start looking:
1. Check all fuses - twice!
2. Wire in a direct 12v from the battery to the battery input on the ECU (pin 58)
3. Check earth wires (pins 60 and 50)
4. If it's still not working start checking all the other wires, for a break or something connected where it shouldn't be.
Hope that helps
Edited by Ryno
Hey mate,
Hope that helps
i found the problem it was one of the relays that is up by the computer plug was missing. thats strange that it would run on the std comp but not the power fc. its running beta than ever even with std tune.
That's good to hear mate,
It's amazing how tolerant the standard computer is to blown fuses, broken wires and missing relays! But it can make plugging in the Power FC a nightmare. I'm just glad it's all up and running now, if I never have to solder a wire in my car again, I'll be a happy man.
Good to here I have a r32 with a rb25 in it as well but with the stock comp in it still, fingers crossed I hope the power fc works in it.
buy the way where is (Hitman) located also that power in a r32 should just do a 12 sec ET.
Edited by RB SANDY
Hitman is located in Penrith, he has a web site (www.hitman.hm) though it appears to be down at the moment. His contact number is: 0417259391
I have done a rb25 swap the Hicas needs a speed signal. my car does not have the speed limiter it's bean tested a few times LOL and my Hicas light turns on and off when it fells like will the Hicas still work or should I put a lock bar on it I don’t want the speed limiter.
I had the same trouble with my car... I decided to remove the HICAS and install a lock bar. By doing so you pull about 20 kg of weight off the car, and then I fitted a R33 power steering pump.
You can disable the HICAS (so you don't get that light coming on) by disconnecting the smaller of the two plugs that go into the HICAS control unit - which is in the boot, beside the rear speaker amplifier.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
