Here in the states, the innovate WBO2 is one of most popular A/F meters. I'd recommend the zietronix WBO2 box however, it's cheaper and unlike the innovate you don't need to buy an extra breakout box for RPM reading, outputs and inputs. It's much cheaper too.
I've used the zeitronix with the datalogit and it worked quiet well.
there is a thread by Sydneykid that has a wideband lamder sensor kit, and full system built that is cheaper than that from memory
http://www.skylinesaustralia.com/forums/in...opic=91356&st=0
Craved,
yer your right i read it as i think i have most post on this forum trying to get a handle on these cars. But this one is not far from Dubai so it is more cost effective to get it from the states than Oz.
And its ready to go so to speak and tried as i have i cant find any one here that knows a great deal about these cars.... all porche over here i am afraid
Edited by tacker
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
