Has anyone flow benched the R34 RB25 head?
For some reason I think a Neo head with GTR ITB's and cams will perform almost aswell as the rb25 head. Is there any real difference between the bare heads?
There isn't any real difference between the RB25DE, RB25DET, RB25DET Neo and the RB26DETT bare cylinder heads, the castings are almost identical. The advantage of the RB26DETT cylinder head is in the hardware (valves, springs cams, followers, inlet, exhaust etc) attached to the cylinder head, not the head itself.
:whistling: cheers :P
:P cheers :D
AHA I knew it. I saw the head pics in your signature that's why I thought of making this post :whistling: .
  • 1 year later...
My engine builder told me that my exhaust valves were 1mm bigger than the RB26 ones.
That is all I have to add.
Ok I'm wanting to revive this thread....
So sydneykid, if, for example someone were to build up an RB30DET (going full house, if you will), there would be more or less no benefit of using the 26 head over the neo25? wouldnt the neo therefore be a better option? variable cam timing...
I mean, if you're changing out the valve springs, retainers, intake manifold etc... is it really worth forking out the extra money for the 26 head? I know the neo has solid lifters (and probably less worn than any 26 head you'll get your hands on, being from newer cars)...
I ask this because im looking at the options for my 32 GTR... it needs an entirely new motor... no i don't have the old one anymore (therefore no 26 head)
What about valve sizes? port sizes? head stud sizes?
Cheers guys (and sydneykid !),
Christian
i had to decide which head to use for my rb30 build, NEO or rb26. I went with the neo mainly being that it hadn't been done bar one person i knew of at the time. Another deciding factor was that it had similar solid lifter desgin to a rb26. I have changed to aftermarket springs/retainers, GTR cams, guides, plenum etc... Its also had a port and polish. Currently still in the workshop so can not add anything more. Interesting to hear that it has larger exhaust valves. Can anyone confirm this? I also was told that it has titanium exhaust lifters instead of steel? Could mean the neo was not a bad choice after all.
Can I ask how much you sourced the bare head for?
:D
I'm still in the process of contemplating putting in a plain-jane 26 (ie. stock), or building an rb30 with neo25 or 26 head... the 26 is costing me $4k (it is in good condition, and has a guarentee)... I figure I can build an rb30 (which would be single turbo) for not much more...
Don't get me wrong, I'm not planning to build a thousand HP competition motor... but I figure, even a rebuilt rb30 on "the cheap" (i'd be doing the build myself... so alot of labour is saved there) would be stronger than the majority of second hand (ie. r32 and 33 rb26's) floating around...
Leaning towards the 30 build, as I've already got quite a bit of shit for a single conversion... bosch 044, greddy type r BOV, Tilton triple plate clutch/flywheel etc...
Car has alot of goodies too... 17x9's all around... coil-overs (kei office), braided lines, new discs... too much to list! :)
:D
the rb30 in a gtr isnt a simple as most make it out, or as cheap. I sat down the other day and did a few calculations for my car and was in abit of shock ahaha (im still doing it lol)
remember with the rb30 you'll defiantely need an awd adaptor (proengines is around a grand), you would rebuild it since its most likely 200k km old, and while your there you'll probably go silly and put some forged goodness in there, thats not including the turbo, manifold etc needed. All of a sudden the engine is costing you over 10k when you can get a used 26 for 4k complete and bolt it in, albeit its not going to be a "fresh rebuild" but theres a reason rb26 are well like, they make great power and are pretty much bulletproof when driven right.
thats the thing mang, as it has been argued before, that 4k rb26 may only last as long as the $200 rb30 bottom end un-rebuilt, yes they're a strong motor but most have been used for their purpose if you get me . imo if you were going to rebuild full stop you might aswell go rb30 :D , the price would be similar to rebuildong an rb26 i suspect
Edited by toffy
I understand everything that is involved :down:
I'm not clueless! I wouldn't buy an adaptor - i'd get one custom made myself... getting steel laser cut is cheap as hell... f**k paying $1000 for a glorified adapter plate. You could get your own made for < $300. I'm just tempted to build a 30/31 as the there is an equal chance that a rb26 will last as long as a $200 rb30 bottom end as stated above... hell, i'd be looking at putting in forgies at a minimum (cheap), and getting the factory rods prepped and checked... new bearings etc. Cams could always come later, they're easy to install...
And yeah I understand all the ancillaries that are required are "extra" (ie. turbo, manifold)...
If you build a motor yourself, a $10k long block will give you an rb30 that will handle 1000+hp... forged pistons, rods, oil pump, waterpump, springs, retainers etc...
I understand everything that is involved :)
Yeah, good luck with the $300 adapter, i made one myself, and its not the cutting or the steel plate that is the expense, its the fasteners, and the 50 odd holes that have to be within about .25mm for it to fit properly. Even if you charge out your time at $20p.h. you are better off buying the kit.
adriano youve hit it on the head
the r&d for mine has cost me in the vacinity of $4000 :) (i was getting them laser cut and tapping/countersinking them by hand, but now have changed to a full cnc process)
Ahhh excellent, didn't realise the Pro Engines kit came with all the fasteners and oil pickup in the kit! that's pretty well priced for what it is then... I thought the original cost was just for the adapter plate - in which case you'd have to be smoking crack to pay $900 for it.
Out of interest, how much for your plates shane? do they come with any fasteners ? :)
Cheers guys,
Christian
Edited by Wobbz
  • 1 month later...
the neo RB25 cylinder head isnt no where near as good as the neo VVL cylinder head in the SR20VE so dont get it miss taken
some people think they are both the same but they arnt
the neo VVL cylinder head found in the SR20VE's run a very similar system to the honda vtec
the cam shaft has a extra set of lobes which it switchs over to at a set RPM the RB25 neo cylinder head does not do this
why would a sr20 head have any thing to do with a rb25neo topic?
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
