Spray Painted Engine Components
benm
 Share
Was down at the local Hardware House today and discovered an isle of Engine Bay spray paints.
I found a nice colour for $10 and spent the afternoon spraying bits n pieces. (including all over my hands and finger nails LOL). I was quite happy with the result as im not a car person and never taken bits n pieces off an engine before let alone spray painted everything.
Hopefully the paint will last atleast until next weekend :( coz I quite like the look of it even if it is just myself that knows. Its often the little things that count I always say.
All up it took me around 4hrs including drying time (3 coats) to do the job. Would have been quicker if I had the correct tools grr.
I want to get braided lines next to tidy everything else up and then i'll be close to happy with the engine bay. Can anyone recommend an online store for these parts or even just for info/pricing/measurements etc?
Fullsize pics can be found at http://skylines.pnc.com.au/pics/ben/gold/
Just some engine heat proof spray paint that was good for metal or plastics. I forget the brand but their was about 100 cans to choose from ranging from like $10-16 depending on brand and can size.
Looks good Ben. Nothin' like getting in there & having a go. Dunno' about painting the rubber intercooler hose joiner though? Go get yourself some coloured silicon boost hoses( red,yellow,blue) it's a tad costly but looks great.
Guest INASNT
benm
did u sand,prime,and clear coat the stuff u painted? If not it might start to peal away soon.
whatsisname
where did u get the blue silicon hoses from?
A few different places.
Autobarn (in Mild End, Adelaide)
ASE
Morpowa
The latter 2 are performance workshops in Adelaide.
It comes in numerous colours, is much easier to route than standard rubber, & look ok :) Not cheap though!
4mm ID - $11 per m
6mm ID - $17 per m
8mm ID - $22 per m
Approximate prices.
GCG in Sydney stock the stuff, as would a number of places up there I'd imagine.
 Share
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
    • DCS, war thunder, IL2 - mostly flight sim games.
