benm, you can get SPEED FLOW braided lines and fittings from STAR PERFORMANCE in Regatta Rd Five Dock. speed flow pricing is a lot less than EARLS, its as good or better than earls, and oz made. go mad with it, but make sure it cant rub on anything. it can be quite abrasive on softer items, like radiators.
dave
nice.. although i don't like the chances of it not scratching too easy - now you can't work on your engine... ever :D
wonder whether the hoses can do with just normal spray paints?? as you can get a wider range of funky colours rather than the high temp stuff. For rubber hoses and things I reckon it could be fine (where if they melt i'd be kinda concerned about the heat anywayz). One day i give i'll give it a try...then i start sanding and polishing some metal bits.
my interior is coming up nice with some touches of cherry red..then i gotta get to the brake calipers and spray them now they're visible.
um...http://www.ryco.com.au/ looks to have a massive selection. for those in melbourne its in footscray. I'd say they'd have everything and anything you'd want from looking at their catalogues. gotta pay them a visit one day too.
You're not talking about painting rubber hoses are you!? If you are it'll be a total waste of time. The rubber will tend to flex (not much but it won't take much!) & most paints don't handle being flexed. And you can forget about ever removing the painted rubber parts if you don't want the paint to crack straight off.
i did a test spray and it seemed to stick pretty well to the bit of hose i had sitting around ... but that wasn't in the car with the heats associated.. true, you don't want bits of paint flecking off - maybe i'm wrong. i'm gonna spray that sucker more then bend it to shittery and see what happens as a test.
Guess silicon hoses are the real solution.
I didn't use any primer or clear just about ~3 coats of gold and it seems to be sticking fairly well.
I mean once everything is back together its only subject to heat, nothing else.
But still i did a bodge job (first time playing with an engine and not exactly a painting expert) and i think my results (close up) reflect exactly that.
If i did it again i'd let everything dry 3x longer and use primer etc etc.
Geez youre engine bay looks sweet now Matt (whatsisname) I really think that is the best engine bay Ive ever seen!
I plan on doing the vaccuum hose, paint and a few other things on my GTR very soon. First im focusing on the metal parts (rocker covers, plenum etc) being polished to a mirror finish. Got half that done. Then will move on to the hoses etc...
I reckon matt, maybe you should have a go at getting the rocker covers and plenum polished up to a mirror finish. That would just top it off.
Do you reckon you could give some of us some tips on doing the engine bay up from scratch? Like where and what to buy, how much we are looking at?
thanks mate,
Andrew
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
