GDay,
Just rang Hornsby Nissan for a price on an RB26 engine overhaul gasket kit. $570! I was just wondering if anyone knew of any alternatives such as non genuine aftermarket kits etc. Im trying to save some money.
Thanks,
Shaun.
GDay,
Thanks,
Shaun.
I'm assuming it's for a BNR32? If so, buy a BCNR33 gasket kit and an oil stariner o ring for a BNR32. Will be about $300 all up.
Yeah, i was quoted for an R32 Rb26. You're a ledgend Mik!!
I've actually bought an R33 GTR kit before and i couldnt remember paying anywhere near $570. I wonder why the R32 kit is so much more expensive??
Anyway, thanks. Ill price the ACL kit too; but where is ACL?
Shaun.
The Nissan i think is $320... cant remember if that was trade or not though.
Always helps to know someone
ACL - http://www.acl.com.au/
HAve a check around there, not sure if there are prices though
Thanks mate.
i got my VRS kit from Lincorp in parramatta (which offer SAU members discounts) for $160 trade without the valve stem seals. its $244 with them.
Holy sh1t, its getting cheaper and cheaper. Im glad i asked the question now!
Ill ring em on Monday,
Thanks,
Shaun.
only catch is you've got to be a financial member of SAU if you dont have a trade card.
How do i become a financial member???
Also, forgive my stupidity, but what does VRS stand for? Been racking my brains all day!!
Thanks,
Shaun.
PS. Was this for an RB26 (32 or 33). Dont you have an RB25?
Thread for joining SAU NSW is here:
http://www.skylinesaustralia.com/forums/in...showtopic=44115
And it will get you cheaper entry to the club events and track days as well as the sponsor discounts.
And VRS stands for "Very Rare and Spensive"
Thanks, ill join then.
VRS thats funny.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
