cars been running great recently , altho started playing up this morning, in traffic my idle was on the piss, almost as if the AAC valve was disconnected all the gether, idle hunting up and down, on the way home from work, i start my car, takes a while to start. and it was blowing flames the entire way home, even at grandma speeds, i can only assume my fuel reg has died?
before people ask, engine is RB20det
Fuel filter is new,
Injectors are clean,
new fuel pump, healthy fuel lines, car is extremly well maintained and i cant find any faults, Diagnostics shows no codes either
any help would be much appreciated
https://www.sau.com.au/forums/topic/122518-insane-fuel-consumption/
Hunting can normally be attributed to a faulty O2 sensor. The easiest test is when the car starts to hunt disconnect the O2 sensor and see if the idle stabilises. Poor fuel economy would also suggest a possible O2 sensor fault.
If the idle does not stabilise when the O2 sensor is disconnected check for an air leak. I would be surprised if it was not the O2 sensor based on the info you have supplied.
Let us know how you go.
Hope this helps.
Cheers
What testing did you do on the O2 sensor? My bro-in-law's car had an aftermarket O2 sensor which was replaced with another aftermarket sensor of the same model and the hunting continued. I thought we could rule out the sensor but when I disconnected the O2 sensor when it was hunting the idle stabilised. Re-connect the sensor and it started hunting again. Hunting would only occur very intermittently. Replaced O2 with a factory unit and hasn't missed a beat.
This is the first thing the skyline manuals say to check for and then spark plugs and finally air leaks.
Hope this helps.
spark plugs are in servicable condition, 02 sensor, i was looking at on consult and it was swinging back and forth so i assumed it was happy, also it looks brand new, and when i had it out of the dump it was pretty fresh,
i just took the car out for a run then, and it was great ,running fine,
one thing i can ad is that before it was playing up on the way home from work, it was requiring a few cranks to start up, it usually starts instantly which it has returned to doing,
have checked ignition timing also for the hell of it, 15-16degres at idle, so its spot on
car is running BP U98 only
been over the car with a fine tooth comb, from afm to the silicon joiners behind the front bar, checked all vacume lines, intake manifold gaskets are new, as are throttle body gaskets and bov gaskets, all exhaust gaskets are new aswell except manifold but i dont think thats relivent here
Edited by Jolinator
yeah, mine was same.. usually around 15L/100km, sometimes up to 18L.. Was tuned, everything checked, stuff replaced methodically, the works. In the end was a lost cause.
When replaced the motor everything is much more reasonable. Never found out what it was. Maybe it was just the signs of a dying engine?
Loss of compression, means not as much power being developed on every compression stroke = more fuel?
just to add to this .. my 1989 R32 GTR is running at an insane rate of about 24ltr/100km and is costing me a mint
the car is pretty much stock besides
-twin pod filters
-boost put up to 9psi
i've checked and there are no visible signs of fuel leaks, i have no idea where to start looking??
tommo you will need a different thread as you have a different car and i cant speak for your cars maintinence history/ condition. pred my car has spot on compression, all cylinders. cant remember the readings, but they were great :P
Edited by Jolinator
i have had the car for over 2 years, and the catch can is compleatly empty with zero mist, even the lines are clean. very minimal blowby, doesnt use a drop of oil inbetween services
Edited by Jolinator
AAC valve causing flamage and backfires, i dont think so :) mine is superclean, i even went to the point of knocking the welsh plug out the back of it, taking the spring out , cleaning it etc, its fine,
its almosst like at random times i just decides to run super rich,
i once used a quater tank in 8 minutes, even tho the car was running fine
anyone else vote for the fuel reg?
Edited by Jolinator
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
