you can thread the wires up the pillar pretty easily. just remove the kickplate and the cover on the side of the foot well, then remove the rubber from the door frame. you can slide the wires up the side of the A-pillar cover and out the hole from the tweeter cover.
stock split wires come together deep in the dash. Dont bother to use them mate, they are pissy wire anyway.
As terminal said, I ran my tweeter wires up behind the kickplates, then between the dash and the body and up into the A-pillar.
woofer(meaning, for splits) wires I just used the stock wires...i know, but i cbf'ed to replace em.
My amp is also under my passenger seat. Just remove the stock airvent under there and run the wires through there. I put some MDF below the carpet and drilled/screwed the amp onto that.
  • 1 year later...
all i did was flick out the cover with a screw driver. unscrew the stock tweeter.. throw that sumwhere ull never find it. run your new wire down tha a piller. n poke it out on the door side.. poke it behind the dash with a screw driver, mount your cross over under the kick panel on the drivers side and ecu cover on passenger side. stockwires for woofer.. jsut take out the door trim (yes there is a screw in the bit that you pull on to close! (tooke me a while :banana:) then i just pulled out the head unit worked out what was the front speaker wire head unit to amp imput on x over. and what that was connected to goes to your woofer out put on the x over. took me like hr n half 2 hrs to do a semi ligit job... also i did mine in pares like both the tweeters mounted, both the woofers mounted, etc etc gd luck
that looks SICK! well done ! and woulda saved a HEAP of time
I am going thru the epic stereo install from hell at the moment haha.. I am just worried I didnt give em enough wattage- 50w RMS all round - I have the Hertz 165's too - so hopefully that gives them enough power
what i did with mine....
  • 10 months later...
I put mine where the stock ones came. I did not have stock ones come with the car, so i drilled holes and put there in there.
To remove that A pillar part, you need to do the following (easiest this way)
- Remove front seats
- Remove door sills/kick panels
- Remove the covers for the seatbelt things
- Remove A pillar thing
Trust me when I say, this is NOTHING compared to removing the rear bar! Just a quick run down of the rear bar
- Remove boot carpet
- Remove holders/plastic caps etc
- Remove plastic from sides
- Remove wall carpet
- Remove rear bar
That takes about 2h, compared to the A pillar ~30 minutes.
In my system, I LOVE the tweeters placed where they are. My Hertz HSK165's are splits, with woofers in the doors and tweeters on the A Pilar. As there is no midrange speaker, the balance is made via tuning the EQ.
Hertz does actually stock midrange speakers, but not on the RS4.
If you want a comment on my sound systems pumpage, I honestly dont think it could sound any better than the way it is, ask Ian, aka humble.
i was skimming over this to see how to get the a pillar plastic off and just had a question. why does the seat need to come out??
thats what mine have, needs more :laugh:
Both AlexCim and myself mounted amps under our seats :D
my stock system still running the stock amp but aftermarket head unit, no need to upgrade my system.
unless it was done in japan ? cause it pumps pretty damn good ;):banana:
and no room underseats for amps, got electric heated seats.
so i saved myself about 800bucks in speakers :D HIGH FIVE!
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
