The long one is a castor rod. Japanese call them tension rods. Essentially they are adjustable and change the castor of the front suspension. Basically castor changes the axis that the wheel pivots on...so when you turn the wheel the actual contact patch of the tyre changes.
Ppl typically tweek castor so that it gives them some camber(dynamic) whislt turning the wheel. When they straighten the wheel it goes back to normal so you are not havign to run excess static camber for corner grip, as thats the sort of camber you normally hear ppl complaining about giving them poor tyre wear.
The second shorter ones are tie rod ends. Basically they screw on the end of the steering tie rod that comes out of the steering rack and is fastened to the hub.
Both pics use ball joints which are pretty racey...some ppl like the directness and feel they give you, others complain about the noise and wear.
yes. The r32/silvia castor rods are the same no matter the brand.
But not all castor rods are created equal :unsure: As geoff said, neither of the pictured items look to be of particularly good quality.
i find the cheaper / generic castor rods to be better, because usually the rose joints are standard sizes and you can get much better quality bearings for them, ie teflon bearings. (i.e. hit up http://www.linearbearings.com.au/ to find info on better quality rod ends for automotive use)
I don't think Tien/cusco have standard sizes, which is why i've avoided them. Bearings are a wear and tear component and should be checked regularly.
(the rod ends www.garage-13.com sell as "dmax castor rods" are the ones i'm talking about they use standard 16L metric rod ends 16mm left hand thread)
Edited by MerlinTheHapyPig
quality of rose joint.. I'm no expert, but there are several factors, basically the material and casting quality of the ball and housing, some have a race, some are raceless Some wear faster than others, are poorly lubricated and i've seen housings break. Buy ones which are specified for motorsport use and you'll be fine. The cheapo justjap/no name brands are usually fairly crappy, but you get what you pay for. "brand name" jap brands are probably better but who knows! the ones i'm using have a nice solid body construction, if you put a good bearing in them they are great. (even the cheapest replacement rod end you can buy ~$15-20 looks better than some of the jap brands)
Infact i broke one myself during a fairly nasty accident which involved hitting a ripplestrip front-on (this is what drove me to replace the bearings with something decent... though probably any rod end would do this after being hit hard enough)
In general, the more you pay the better! you can pay over $100 for a rod end.
i can't download that pic for some reason,
longer castor rod = less castor, which is probably not what you want
Most brands will allow for roughly the same level of adjustment, maybe it just looks longer in the different pics
keep in mind also. S13/r32/z32 are all the same, but awd r32's have different rods.
    • Be more active mate.. , not taking the piss ❤️, your long term health will love you for it I would think something like a kettle bell or 2 laying around in areas you go past during the day would be awesome for ADHD.... "Oh look, a kettlebell", and exercise helps your brain health as well My mates son was a bit of a problem child, diagnosed wirh ADHD, and some other things that had his brain occasionally doing loops, until we got him into a training program, the difference after he started training was amazing, he had more focus, and his fitness levels exploded, it is like he is a totally different kid to be around Brain chemistry something something Stay fit stay strong mate
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
