  • Replies 118
Posted Images
I would have to say its the baby itself, rather than a spirit in the house which is causing the problems... when the bed itself rocks gently, much like a cradle, you have to be suspicious. The baby is rocking the parents to sleep!
Perhaps the baby has a powerful spirit and is just getting used to life in this plane? If that is so then the problems should stop after awhile. You could try making sure the baby is as comfortable as possible when going to sleep and is in general quite relaxed.
I would recommend that you get an energy worker, such as a Reiki practitioner (you could probably find one who could help where classes about Reiki are taught) or a psychic. A Buddhist monk (a senior one who is very experienced at meditation) would also probably be able to help. Pretty much every high-end meditation book mentions that you will encounter spirits and beings from other realms when you get to higher levels of meditation. So the monk could help see if it is an actual spirit or whether its the baby's latent power.
Also don't forget that everything happens for a reason... perhaps this is some kind of lesson in spirituality for the couple. it might not be too wise to get involved too deeply.
Lachie
it could be the spirit of a kid that's always been in the house.
it might not have been threatened when the couple was just that, but when a kid came home it cracked the shits.
similarly, when the sister / husband / kid moved in for the week, the kid may have threatened the spirit.
also, has the kid been present in every room when the incidents
happened?
has the kid reacted at all, or changed demeanour during the incidents?
I used to work in a production house in southern england back in 2000 which was practically a medieval church and deemed to be haunted. The old war tunnels under the town used to lead to right to this church. Anyway I used to do very late nights working alone and on several occasions I'd feel brushes of wind on the back of your neck which would really get the hairs standing on end. Also as it was a double storey I could often hear heavy footsteps upstairs on the wooden floors (I'm the only one there)...very eeeery at 1am let me say!!
  • 2 months later...
ahhh hahahaahahahahah
Hey woman! its not funny - all i saw was something about a puppy or something in jamezillas post and so i expected something like a labrador or a beagle pup - didnt expect that "thing" to appear!! :laugh:
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
