  • Replies 118
Posted Images
I would have to say its the baby itself, rather than a spirit in the house which is causing the problems... when the bed itself rocks gently, much like a cradle, you have to be suspicious. The baby is rocking the parents to sleep!
Perhaps the baby has a powerful spirit and is just getting used to life in this plane? If that is so then the problems should stop after awhile. You could try making sure the baby is as comfortable as possible when going to sleep and is in general quite relaxed.
I would recommend that you get an energy worker, such as a Reiki practitioner (you could probably find one who could help where classes about Reiki are taught) or a psychic. A Buddhist monk (a senior one who is very experienced at meditation) would also probably be able to help. Pretty much every high-end meditation book mentions that you will encounter spirits and beings from other realms when you get to higher levels of meditation. So the monk could help see if it is an actual spirit or whether its the baby's latent power.
Also don't forget that everything happens for a reason... perhaps this is some kind of lesson in spirituality for the couple. it might not be too wise to get involved too deeply.
Lachie
it could be the spirit of a kid that's always been in the house.
it might not have been threatened when the couple was just that, but when a kid came home it cracked the shits.
similarly, when the sister / husband / kid moved in for the week, the kid may have threatened the spirit.
also, has the kid been present in every room when the incidents
happened?
has the kid reacted at all, or changed demeanour during the incidents?
I used to work in a production house in southern england back in 2000 which was practically a medieval church and deemed to be haunted. The old war tunnels under the town used to lead to right to this church. Anyway I used to do very late nights working alone and on several occasions I'd feel brushes of wind on the back of your neck which would really get the hairs standing on end. Also as it was a double storey I could often hear heavy footsteps upstairs on the wooden floors (I'm the only one there)...very eeeery at 1am let me say!!
  • 2 months later...
ahhh hahahaahahahahah
Hey woman! its not funny - all i saw was something about a puppy or something in jamezillas post and so i expected something like a labrador or a beagle pup - didnt expect that "thing" to appear!! :laugh:
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
