wastegate actuator rod shouldnt budge unless you're pulling quite hard.
the backfiring noise is normal. when you BOV vents, it vents out air that is supposed to go into your combustion chamber. this causes the a/f to richen up at that point. the richer mix then ignites in your exhaust causing a loud pop.
its probably air being pushed back onto your turbo blades. aftermarket BOV's usually have harder springs which will sometimes stop the valve from opening under normal driving with standard boost.
if your BOV is adjustable, try putting it on the loosest setting, go for a drive then get back to us.
it seems to be ok now for some reason. lol my line is quite a freak car really. does anyone kno how to tell the difference between a r32 standard turbo an a r33 one just by looking at it, an are standard 32 turbos supposed to hit full boost a 4grand?
I think the R33 turbo is noticeably bigger, and the markings on them would tell you which is which.
The bigger turbo would probably lag longer, although it is ball-bearing and ceramic exhaust wheel, i'm not sure it would make up for the smaller motor.
So, at a guess, with a decent exhaust/dump, it probably SHOULD fully spool to 7psi or whatever by 4000 (under load at least)
judging by your avatar, i could guess that the problem is that bigass bov you have on there. causing overfueling when you lift off, regarding actuator rod, they arnt very easy to move by hand, go get some multigrips.
why is it that smart ass's like u come n here an an cause sh^t, the BOV aint that big mate.
these are serious questions an id appreciate serious answers if not dont bother posting,
Edited by HR32_GTS-T
he's actually quite correct regarding the BOV.. ALOT of people have problems with their cars stalling and backfiring because of them.. So maybe think before having a go at people..
Does it do it when the car is warmed up - all the time.. or just intermittently??
Edited by Links
ahhaah , your an idiot, strait up, i was being serious and if you notice i have been trying to help you through out the thread, f**k it, you go on to abuse me, some days after i post it aswell, wtf is wrong with you, lols goodluck fixing your car twat, i was acutually going to post up last night ways for identify which model turbo is on your vechile but your such an ignorant prick it would be a waste of my time
Edited by Jolinator
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
