Everyone knows the r33 owners are pissed about their headlight lenses getting all yellow/cracked. I just was wondering what people are doing about it?? I've done what most owners do which is polish up the outside with metal polish, but the plastic itself has many fine cracks in it, and the inside surface is yellowed anyway.
Is there a way to get new lenses custom made (like in perspex or something) because i assume you cannot buy jlenses aftermarket.
What i really really want is a setup like this:
But i've searched high and low but cannot find them for r33's, although i do recall the autostyle kit for the r32, but that doesn't help as i dont think they did ones for the r33 :
So yeah, has anyone come up with a way to get rid of the horrible lenses that doens't involve a $1000 set of new lights or something??
https://www.sau.com.au/forums/topic/122669-the-headlight-issue/
there is a place in Blacktown called plastifusion (i think thats it) anyway they recondition headlights and tail lights. not 100percent sure but i think they are on sunnyholt road.... look them up, try to call them. see if they can help you out.
I've heard heeps about aftermarket lights for the R33, and ever time i've herd there a fair bit over your $1k mark :cool: so i think for now were all stuck with these shitty ones. :laugh: I'm actully thinking of doing a S2 conversion in a S1 they seem alot nicer. Any comments on that guys, do you think it will fit???
    • The way they do the test you would be very lucky to ever hit any cell that isn't aiming at 14.7 This was my result... Really not sure what's going on there!
    • I have a projecta one.  A proper trickle charger can be left attached 24x7, that's what the trickle bit is about.
    • With an electronic boost controller, there are settings available to limit overboost.
    • Ah ok, my tuner did adjust something on the percentage cycle on the boost controller, instead of running at 40% the tuner put it on 20% to compensate for the overboost, can't remember what it was. Not duty cycle don't think, and told me if it keeps overboosting, it's going to be something else. I think he mentioned the turbo actuator.
    • Which trickle charger does everyone use? I'm going on holidays in the future, and last time it was left for a couple weeks off twice per time, and don't want to keep doing it to damage my battery so looking to have something hooked up to the battery which connected to the car, as I need to keep my immobiliser system on. If the battery goes flat it will mess up my security system (already happened once) I was looking at the following, so can have someone turn it on every couple of days and run it overnight then turn it off)   https://www.supercheapauto.com.au/p/noco-noco-genius-5-battery-charger-6v-12v-5-amp/648987.html?cgid=SCA01060203#srsltid=AfmBOoq4kzQgrm1YHSZT0DzaCwVwwOcevgu0TSDcUvrNeOqI-0S5xJ1C&start=1   https://www.supercheapauto.com.au/p/century-century-cc1206-xli-12v-1-3-6a-9-stage-battery-charger/693006.html?cgid=SCA01060203#srsltid=AfmBOoq4kzQgrm1YHSZT0DzaCwVwwOcevgu0TSDcUvrNeOqI-0S5xJ1C&start=30   though these don't say anything about trickle charging, don't want it to overcharge the battery.
