Guest INASNT
Ok I been wanting to do this for a long time to my car so here’s the plan for my 250rwkw’s
This is what I have budgeted for each part.
1 x New turbo (GCG rebuild or custom garrett) - $2000
1 x Z32 AFM - $300
6 x 500-600cc injectors - $700
1 x Bosch 044 fuel pump - $250
1 x New clutch (what would be good for 250rwkw + drivability in heavy traffic? thinking twin plate or organic) - $800
1 x PFC ECU - $1450
1 x S/S intake pipe - $100
1 x EBC - $650
Things I am unsure about are weather I should get
1 or 2 x adj cam gears - $250 each (do I need 2?)
2 x new cams - $??
I also plan to sell my old parts when I change everything over.
1 x stock turbo - $450
1 x stock afm - $150
6 x stock injectors - $300
1 x stock fuel pump - $100
1 x stock clutch - $250
1 x stock ecu - $250
1 x 2 stage boost controller - $230
are these prices around what I can buy/sell at?
Also for installing/removing all these parts how many man hours/$$ should I leave for this? I have the $$ for most of the parts at the moment but will probably buy a few at a time.
https://www.sau.com.au/forums/topic/12268-my-power-upgrade-plan/
sounds great inasnt
thats all you need you only need one cam gear forget the cams for now 1k + for them.
If you go gcg go the stage 2 at least.
go the organic clutch much easier on the foot.
every thing else sounds good.
try to make your power @ aroudn 1 bar of boost so tell gcg that when you order the turbo you might get some lagg but it will be better for engine life
cheers
meggala
yeah the flywheel is good.
get your self 11's if you go for a turbo combo thats good for helping the motor make 400HP. The turbo will be rated at 450HP max flow I guess as a rule of thumb.
Some good rear tyres would be worth while. Apparently ford falcons have the same PCD on their rims. That means Mickey T's on a set of old 14inch ford mags for the drags, so you can do 'street tyre' passes.
INASNT,
just what you might want and at a very good price also.
http://board.performanceforums.com/forums/...readid=67145892
btw, sounds like a very nice plan but i'd stay away from the twin-plate clutch if it's a daily driver.
that's fair enough INASNT although i guess you can get the turbo and wastegate checked out by a turbo specialist and if at the worst case, a turbo rebuild will only cost around $400.
wastegates don't usually stuff up, so that should be ok.
it's a pretty good price considering you get an external wastegate, manifold and dump pipe with the package.
re: clutch - if you can find a centreforce clutch kit, i'd go for this with a sprung centre ceramic puck clutch, very streetable and offer very good clamp force.
do you have a preference for a ball-bearing turbo or it doesn't matter as you can get yourself a very nice bush-bearing turbo combo for way less than $2k.
did u speak to dennis at P.E.T?
I'd recommend you do, he'll be able to help you out with a good turbo combo for the RB25.
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
