Hi everyone I'm looking for opinions about twin turbo setups and the possibity of one turbo surging back through the I/C pipes onto the other turbo?
I noticed while my car was on the dyno the there was a faint intermitant fluttering noise from the turbos at low revs, was this the turbos blowing back on each other?
If so could this cause the exhaust wheel to slow down in the path of the exhaust gases and become dislodged? as this id what happened eventually to the r32 gtr turbos, or is that just the fate of ceramic wheels :O
any ideas or discusion would apreciated
cheers sara
https://www.sau.com.au/forums/topic/122705-twinturbo-surgedead-turbo/
what turbo's are u using? you should have twin bov's and a joiner pipe between the intakes to balance out the pressure difference. have a search for compressor chuffing shuffling, as it sounds like that
they are t28 turbos with equal length to a collector just before the I/C
The BOV is just infront of the T/B and works ok on back off, ie theres no flutter on back off just when the engine is running slowly off boost, sounds like water dripping slowly onto to a hot bbq plate
