I reckon the Bob Jane bashing is out of line. The chain requires them all to have laser alignment machines for proper HICAS friendly alignments.
Yes if you don't tell them you want something special you will get an alignment designed for commodores (eg toe in to reduce tyre wear due to camber).
But if you tell them what you want and get a print out of the before and after settings you will get the right result.....
I have been to bob janes all over the east coast and tassie when racing and they are always happy to stay open late and help out. In fact the one in Hobart we went to when we broke the rear steering rack at Targa let us use the workshop all night.
Yer it is out of line but here in Adelaide for some reason they all hire young blokes that have just dropped out of school.
But they machines etc are all top notch. So its a matter of finding one that has non-thrasher looking ppls working. :spank:
in regards to the hole hicas thing.. if your kinda stupid like me and dont realy no the settings etc, what do you tell em ?? just that the car "has 'hicas" ?? cause i found alot of places werent familiar with that...
Ok, I dont just sledge Bob Janes Stores.
I am willing to sledge any other companie I worked for that I know is dodgy... And it just so happens that 99 out of every 100 people you talk to in Adelaide will tell you the same thing as me, "To not go to Bob Janes cos none of them 16 year olds know anything about what they are doing"
It isnt a matter of how good there system is, or the machines they are using.. you will still always find that if the guy using them knows nothing, then the machines are useless.
But Sydney may be different, They may hire people that know how to do a Wheel Alignment, instead of a Thrust Alignment..
Thurst Alignment: commonly known as a bob jane special, or a toe and go.. all that is altered and chekced is the toe readings on the car, no cambers or castors are checked in this process.
And I dont see stating the truth about a company I worked for as sledging.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
