I have tried quite a few different types of clamps to try to remove the oil filter and been disappointed by all of them and end up using the screwdriver through the side technique.
post-17300-1150626497.jpgExecpt this one bought at Repco for $10 the other day. Most of them use a handle that is in line with the filter and usually gives no room to swing it in the engine bay but this one uses a socket wrench fitting along the axis of the filter and it is no problem for swing as it is well away from the motor and it actually grips it with no problems.
To some on here it will be old hat but I didnt know of this type as others probably dont.
https://www.sau.com.au/forums/topic/122751-oil-filter-clamp/
this is brilliant....I have the other crappy type of filter wrench (el-cheapo inline thing)...it's usually fine for the skyline, but it caused over an hour of swearing when working on my parents Mazda B2600 ute, there's absolutely no room around the filter for the tool I have....I eventually loosened it, not not without completely squashing it with g-clamps hoping these would work better! :D
That is a fairly good generic tool.
I use one of these.
It's made by Lisle tools and also available through repco - approx cost $40.00
It is made for a 15 fin, 80mm oil filter. On a RB25DET it is the easiest fit you will ever get.
It fits most filters, repco, valvoline etc, however it will not fit the ryco z145a filter.
Edited by frx026
oil filter only really needs to be tightened to 16Nm. you can achieve this by hand tightening it, as long as you place a small film of oil on the seal when installing one, it should be reasonably easy to remove by hand.
Mine is stuck on so tight I bent the filter wrench I have, so I'm just going to get my mechanic to do the old screwdriver trick for me. Saves me a little money and when the new filter goes on, I'm making sure its on hand tight (+ 1/4 turn cause I can't get a great grip on it) AT MOST! This means I probably won't even have to use any sort of filter wrench/socket/whatever to remove it next time.
I'd like to slap around the moron who put the filter on before I bought the car.
Fixxxer
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
