spray guns,grinder, etc, have gurantee.The original price was $2400. I will sell all my equipment for $1500. Give me a e-mail if you wish to buy it. Email address is [email protected] If you can come and buy soon, I will some discount. And I have big TV(1year old) and wantto sell it too. price is $250. http://users.tpg.com.au/sirosiro/images/TV.jpg
I live in Broadmeadows in victoria.
Thanks
Compressor 2HP with 40L tank and air hose 20m
http://users.tpg.com.au/sirosiro/images/compressor.jpg
spray gun 1.4mm Gravity feed with water trap
http://users.tpg.com.au/sirosiro/images/spray_gun2.jpg
spray gun 2.0mm suction feed
http://users.tpg.com.au/sirosiro/images/spray_gun1.jpg
spray gun 1.8mm no cup
http://users.tpg.com.au/sirosiro/images/spray_gun3.jpg
spray gun 2.0mm broken. as spare parts
water trap with regulator
http://users.tpg.com.au/sirosiro/images/water_trap.jpg
Huge exhaust fan 50cm x50cm(was $1600)
http://users.tpg.com.au/sirosiro/images/124.jpg
http://users.tpg.com.au/sirosiro/images/exhaust_fan.jpg
Air hose 10M good one
http://users.tpg.com.au/sirosiro/images/air_hose.jpg
primer surfacer
http://users.tpg.com.au/sirosiro/images/surfacer.jpg
spray putty
http://users.tpg.com.au/sirosiro/images/spray_putty.jpg
angle grinder
http://users.tpg.com.au/sirosiro/images/grinder.jpg
panel beat hammer set
http://users.tpg.com.au/sirosiro/images/pa...ting_hammer.jpg
hydraulic jack for panel beating 4ton
http://users.tpg.com.au/sirosiro/images/hydraulic_jack.jpg
orbital polisher with 3 polishing cloths
http://users.tpg.com.au/sirosiro/images/orbital_polisher.jpg
orbital sander for painting
http://users.tpg.com.au/sirosiro/images/orbital_sander.jpg
cutting compound set Fine and zero swirl
http://users.tpg.com.au/sirosiro/images/compound.jpg
240W lamp for painting
http://users.tpg.com.au/sirosiro/images/white_lamp.jpg
Cutting compound 3L
http://users.tpg.com.au/sirosiro/images/cutting_compound.jpg
Dice set mm scale
http://users.tpg.com.au/sirosiro/images/dice_set.jpg
electronic drill with 2 battery
http://users.tpg.com.au/sirosiro/images/el...ll_2battery.jpg
paint for practice pearl red
http://users.tpg.com.au/sirosiro/images/paint1.jpg
http://users.tpg.com.au/sirosiro/images/pearl_red.jpg
paint for practice metallic blue
http://users.tpg.com.au/sirosiro/images/paint2.jpg
clear for lesonal paint 1L and hardener
http://users.tpg.com.au/sirosiro/images/clear.jpg
cleaning thinner
http://users.tpg.com.au/sirosiro/images/cleaning_thinner.jpg
fibre putty
http://users.tpg.com.au/sirosiro/images/fibre_putty.jpg
normal putty
http://users.tpg.com.au/sirosiro/images/putty.jpg
lamps for garage
http://users.tpg.com.au/sirosiro/images/garage_lamp.jpg
extension lead
http://users.tpg.com.au/sirosiro/images/extension_lead.jpg
heat gun
http://users.tpg.com.au/sirosiro/images/heat_gun.jpg
waxes
http://users.tpg.com.au/sirosiro/images/waxes.jpg
3 applicators
http://users.tpg.com.au/sirosiro/images/applicator.jpg
ignition coil
http://users.tpg.com.au/sirosiro/images/ignition_coil.jpg
battery charger
http://users.tpg.com.au/sirosiro/images/battery_charger.jpg
gas mask and spray putty
http://users.tpg.com.au/sirosiro/images/gas_mask_spray putty.jpg
spring compressor and steering handle lock
http://users.tpg.com.au/sirosiro/images/sp...mpressor_handle lock.jpg
locking plier and adjustable wrench
http://users.tpg.com.au/sirosiro/images/lo..._adjustable.jpg
scouring pads
http://users.tpg.com.au/sirosiro/images/scouring_pad.jpg
waxes
Tools set(few tools are missing)
http://users.tpg.com.au/sirosiro/images/tool_set.jpg
tools for drill
http://users.tpg.com.au/sirosiro/images/tools_etc.jpg
big sockets and lots of tools
http://users.tpg.com.au/sirosiro/images/tools_etc2.jpg
tie rod end puller
http://users.tpg.com.au/sirosiro/images/ti..._end_puller.jpg
rust converter
http://users.tpg.com.au/sirosiro/images/rust_converter.jpg
mask tape
http://users.tpg.com.au/sirosiro/images/masking_tape.jpg
sand papers
http://users.tpg.com.au/sirosiro/images/sand_papers.jpg
sponges
http://users.tpg.com.au/sirosiro/images/sponges.jpg
small lamp
http://users.tpg.com.au/sirosiro/images/working_lamp.jpg
air plugs
http://users.tpg.com.au/sirosiro/images/air_plugs.jpg
kerosine
hydraulick lift jack
http://users.tpg.com.au/sirosiro/images/jack.jpg
https://www.sau.com.au/forums/topic/122766-moving-house-re-spraying-equipment/
