I just got off the phone with Constable Woods from Riverwood Station. My car just been found and is now in their posession. I'll be calling them tomorrow to get the details and hopefully take her home. Apparently it was just a joy ride and left it at Punchbowel.
I do hope the thieves get caught but nothing could describe how relieved and happy I am at the news.
A big thank you to all you guys and your kind words, and especially Liz for cheering me up.
OMG THIS IS AWESOME!!!! I feel whole again.
Edited by lingeringsoul
https://www.sau.com.au/forums/topic/122772-yay-my-car-has-been-found/
  • Replies 42
Excellent News dude. Glad you got it back.
btw i think your referring to Sergeant Woods. Good friend of mine. My teachers husband to be exact.. hope you don't mind if i ask him about it?
no problem go right ahead and ask
Very good news, Now lets hope they catch them. Missed you last time you guys were in newcastle, now there might be a next time. Cheers and hope she isnt to worse for wear! :D
apparently, it was just damage to the ignition when they stuck a screw driver into it
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
