Hey I used Ambassador Car Care 92407709.
Guys name is Nunzio, tell him David with the 4 door Skyline from the newsagent in Girrawheen sent you. Will make your car look fantastically new again! I'm not joking! A little expensive but if you want it done perfect then bring it to him. I couldn't beleive how my car turned out after!
He does all of Barbagallo's cars.
My opinion anyway :D
If your a south of the river boy theres a great place in Augusta st. Willeton. Sorry not in Perth to find his card, Single unit next to the lunch bar. Great job on my R to get rid of the Tokyo grime. Does alot of show cars and high end euro stuff, took most of the day but worth every penny.
