Simon Evans won heat 1 and overall but Scott Pedder won heat 2 as Simon took a 30sec time penalty overnight so he could change gearbox
Enjoy the pics
Oh and of cource the grid girls and boy
Rest of the pics are here http://www.pbase.com/joelstrick/rallyqld06
https://www.sau.com.au/forums/topic/122788-rally-qld-pics-2006/
I was there and enjoyed the day alot...
I also got a few pics but nothing compaired to yours...
My L series lens is being repaired ATM after it was damaged in Fiji so i was stuck with my 18mm F2.8 and ended up having lighting issues near the corperate area with lack of sun light through the trees...
Then to top it off by the time the sun was bright enough i was too drunk to continue with the photos and had the Mrs take photos from lunch time on... :D
Here are a hand full of my pics...
http://www.skylinesaustralia.com/forums/in...howtopic=122675
Then to top it off by the time the sun was bright enough i was too drunk to continue with the photos and had the Mrs take photos from lunch time on... :)
Nice stuff, yeah I was looking at that corporate marque and wished it was was me sinking the beer
its a great event and the specy points were good too
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
