I got an Exedy Heavy Duty clutch for $420 from Martins Clutch & Brake in Campbelltown.
The cost for installation is pretty hefty, my mechanic quoted me 5 hours, and I can see why. I ended up doing it with the help of a couple of mates, took us 3 days, it is a mission of a job.If you pay someone to do it, expect to pay upwards of $400.
If i'm not wrong, the 32 GTR clutch is the 'Pull Type' not the normal 'Push Type' like the 33 GTST. Pull Type clutches will cost about minimum $700ish for a basic one.
the earlier model gtrs are push type i think up to 91-92 are push type 93 and up are pull
Im about to get mine down tomorrow. Mines a 33 gtst ill let you know what it costs me.
I just bought a exedy heavy duty organic off a group buy here for about $350 I have budget around $400 to put it in I hope its not more.
Chris
i just fitted one into my sons car with his help in a r33 gtst it was one of the clutches brought in here with a group buy. actually fitting time took us about 4 hrs total had to wait a day while getting flyweel machined.hardest part of the job was getting the top bolt of the starter moter altho it went back on easy lol . 350 to 400 bucks sounds about right if there machining the flywheel as well .and while you have it all apart check ya rear main seal as well may as well do it if it looks suss. gearbox took about 3.8 litres of fresh oil as well
good luck with it cheers
Chris
If yours is a 33 GTST, then you are looking at 5 hours labour - about $350- 450 depending on your mechanic.
Hence the reason I did mine myself.
yea thanks for al the comments guys just suks a gota do a clutch already only had the car since saturday and im abit short on cash after just buying it and i wana be able to b able to drive it properly but the clutch is rooted wasnt that great wen i got it and after a few nice launches it was all over lol :P:(
You machine the flywheel and do the rear main seal?
The flywheel cost $44 to get machined, we checked the rear main and it looked ok so didn't bother changing it. Just changed the flywheel, clutch plate, pressure plate, thrustbearing and gearbox oil. Like I said before, if you are doing it yourself it is a mission. We didn't have a hoist or anything, just the car on stands and 2 jacks to lift the gearbox.
yea thanks for al the comments guys just suks a gota do a clutch already only had the car since saturday and im abit short on cash after just buying it and i wana be able to b able to drive it properly but the clutch is rooted wasnt that great wen i got it and after a few nice launches it was all over lol :D:dry:
I know how you feel, mine went a week after I got it too.
alphanumeric: If you have budgeted $400 to put the clutch in, it will probably go over, but not by much. My mechanic quoted me 5 hours, which was $400, but that was an estimate, could be a little more or less, depending on how good your mech is at doing them.
The cost of the flywheel machining will probably put it over, but it will be close. If you are doing the rear main as well, your budget will explode big time.
Edited by Quinny
I can offer you an Exedy Heavy Duty Cushion Button Kit for $570.50 delivered, for details on this clutch click here.
Also I would be questioning your mechanics quote of 5 hours, as I know it's only a 2 hour job, 3 tops if something does not cooperate.
  • 2 months later...
so what do you expect to pay to have a clutch fitted, i have been quoted $440 that includes getting the flywheel machined
the price seems ok but mabye a little high if it really is just a 2 hour job for a good mechanic or is that what mechanics are charging at the moment?
$200 per hour?
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
    • Well, moulded carpets should fit well if the buck they use is the right shape. The finish is then just a case of stiching the trim around the edges. Shuoldn't be too hard to get it right. Back in the day, replacement carpets were all "fitted", in that they were stitched together, with cuts and slices taken out to make them form the shapes. Many more opportunities to get it wrong, hence all the concern over good vendors and bad vendors.
    • A timely blog via AASA (keeping in mind they sell brake fluid of course...) https://www.msbgarage.com/blog/news-and-blogs/brake-fluid-what-should-i-use/
