hi guys,
just wondering would there be an advantage of using a tyre with a bigger wall e.g (60) for less wheel spin of the line?
for e.g i used my 17/45/235 rims (potenza gIII) last time for the 1/4 mile and it was getting heaps of wheel spin (b/button clutch) if i used a 16/60/215 but flattend to say 16-18psi would it grip more as the tyre has more flex on the wall?
https://www.sau.com.au/forums/topic/122799-tyre-heightswidth-for-14-mile/
Think about it logically for a second. Why does increased sidewall flex give more grip?
The deformation of the sidewall then increases the effective surface area because the tyre squashes and spreads.
But if you're going with a tyre that has less contact patch, then all you're doing is getting it to a point where the contact patch was the same size as the less flexy but wider tyre.
Obviously the final word will depend on the specific application and would require testing, but logically all I can see happening is you having the same amount of grip.
If you were going to a 235/60 R16 tyre from a 235/45 R17 I'd say yes, but since your "new" tyre choice is narrower I'd say it was pretty line ball (assuming your tyre is the same make and model).
thanks, ye that sounds right, just had a few ppl tell me dont bother with rims (something like a 45 profile) as it will only spin especially with a b/bustton clutch, i will be testing both sets of tyres this saturday so wel see what happends,
has anybody had any Actual experiences were they have compared a both smaller and larger profiles?
The bigger the diameter, the harder it is to spin. The wider the tyre, the more grip. The bigger the profile, the more it will absorb the shock from take off. The lower the pressure, the more it will absorb the shock from take off, and increase contact patch. This is all assuming all other this are equal. Also big burnouts are bad for street tyres, but good for race tyres, if using street tyres, try driving around the water box and just spin the tyres enough to make sure they are clean ie no stones etc.
Wrong. By your logic, Top Fuel cars would be using 60" wide slicks with 40mm of sidwall and running the times they are - or better!?!?!?
Adrian
ye that right,
so im assuming the 16/215/60 will work betta say at 18-20psi than the 17/235/45?
i think the main problem is the clutch coz it so frictiony and its pretty much impossible to ride and from the take of shock/stress on the small profile just starts spining. the car makes just over 200rwk.
any ideas on a better take of strategy
the 17's are potenza gIII's, and the 16's are good year eagle ga
The width of the tyre also makes a big difference, people often state that to increase grip you should fit a wider tyre, but thats not always true, your cars weight is simply spread over more surface area of tyre with a wider choice, a narrower tyre can actually provide more stability.
Matching your cars gearing to the your tyres diameter is also very important. Genrally the samller the diameter wheel/tyre the better the acceleration, but lower the top speed.
Tyre pressures also effect the cars grip, as does the friction co-efficient of the tyres rubber, the weight on each tyre and the force applied to them.
Mate,
as a guide - I have dunlop 3000R's on my 33gtst - just a normal road tyre basically!
225/60/16
I dropped the pressure down to 22psi and was doing 1.9 60 footers at WSID (stock clutch) with a gay effort burnout haha
that might help you in theory >_<
Edited by evil_weevil
Mate,
225/60/16
that might help you in theory :D
thats a pretty mad 60'' time man, ye standard clutch is much better than b/button as theres no ride in the clutch its on or off, so wen u try take off at 3-4000rpm ~~~~~
what was your finanal 1/4 mile time with a your 60' at 1.9 and mph?
Usually fitting the widest possible tyre to the rim will give you good traction. You know how some people stretch 225s over 9" rims. Well you want to do the opposite basically. The sidewalls will flex more and the contact patch will be better to begin with too.
This is probably the reason why evil_weevil was getting good 60 foots, because of the fact that 225s are wide for a 6.5" rim.
no....I thought it was because I'm such a skillful driver?? hehehehe jokes :whistling:
Some people thought I was running semi's because of the 1.9's.
Launching is an art - their is more to it then how wide your tyres are or what brand of rubber they are.
Track prep, track temperature, clutch type, tyre compound, tyre pressure, horsepower, rpm etc all influence your launch.
On a side note I have a pair of unused 300ZX rims with very very warn Nitto NT555R rubber (255's) sitting in my garage if someone wants to throw some mulla my way :laugh:
I can tell you that someone should use ben's tyres asap. Those tyres have gone 1.68 60' before :D Awesome
I can tell you that someone should use ben's tyres asap. Those tyres have gone 1.68 60' before :laugh: Awesome
i would take them, but i live in melb spuin an need them for saturday,
any special take off techneeks with brass button clutches? were u cant really ride? ive tried hand brake helps a little
TOY - practice makes perfect?
keep practicing and you will soon find out the best way :laugh:
Adrian - In the NSw times thread - most other people are doing 2.0 + 60footers, m impressed with my efforts :D
keep practicing and you will soon find out the best way :P
Adrian - In the NSw times thread - most other people are doing 2.0 + 60footers, m impressed with my efforts :O
Didn't mean it to sound like a knock, mate. Good work on the times! Just wanted to make the point that the 60' was about right for a more than capable driver on crappy tyres. More of a compliment when i thought it than when i re-read it.
Buy some better rubber champ - you wont know your car!
Adrian
hahaha Oh I know you werent having a go mate, sorry if I came across like that !!
In my old VT LS1 my best was 2.3...hahah
Yep - Going to do some research with the tyre rating thread asap and get some good rubber !!
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
