You all know I am not up with all the technical terminology, so I will state it simply. In wet weather my backend is all over the road. This happens whenever I take off from traffic lights, and when I turn corners.
It is not just that I am a bad driver (I hope) I am only going to 1500 revs to take off, as I am particularly careful in wet weather.
Could anyone give me some tips to stop this, and I wanted to know if a good set of tyres would help at all. The tyres on it are only six months old, so I wondered if I could just get good tyres for the back. If it will stop my backend from sliding, I would be happy to spend up to $300 per tyre (only for the back).
https://www.sau.com.au/forums/topic/12288-tyres-1994-r33-gts-t/
angel,
You need some Diff cradle bushes. Whiteline suspension does the kit part number KCA349.
This kit installed in the traction position will give a better chassis transfer of power.
You will find cars that have suspension set too low or hard at the front suffer badly from traction issues also.
As for tyres,
The good old simex brand are fab for the price. Get a 225 or 235/55 for the back ( a fairly tall profile for good sidewall flex at the drags). Don't buy the simex tyres for the front tho' they radial roll too much.
My little 205/55 simex tyres got me a 13.4 second 1/4 so they are not a bad pick.
the kit cost less than $120.
Takes 10 to 20min to install. I did mine by myself with a big iron bar and almost crushed my fingers into jam but, an ordinary two person team can do it with a minimum of fuss and no danger at all.
Bat the eyelids at some of the perth boys to give you a hand, if that doesn't work then offer free beer. Or do both. You might want to make sure that the helpers have done the install before having said that.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
