hey guys
just had a another question
with the stock ceramic turbos ive heard that its impossible to know when there gona blow up but it will happen
everyone sort of says its the heat that kills them
like if ya run a bar boost or new cams etc etc
i was thinking today that maybe its the oil lines clogging up over time and blocking
leaving no oil going to the turbs and then just burning away till a ceramic explosion
what do you guys think??
or am i just talking shit
g
https://www.sau.com.au/forums/topic/122901-ceramic-stockies/
  • Replies 64
Posted Images
if you could keep the exhaust wheel and shaftat an even say 25oC, the wheel would not explode.
if its pumping 15psi @150,000rpm for 30 seconds @ 1200oC it will die fast due to expansion
if its pumping 15psi @150,000rpm for 10min @ 10oC it will stay together as long as the temps are even, and consistent
A ceramic wheel or shaft should be more heat tolerant than a steel one. Cermic pieces are fired at over 1000*C, steel won't take that. I would think that it would be the pressure of the forces pushing a ceramic shaft at very high rpm that would cause ceramic to crack, where as a steel blade will be much more tolerant than these forces.
Just my 2c.
In short,
Aim to keep those EGT's down.
What raises EGT's one engineer may ask another?
Reduced Timing
Detonation
Lean mixtures
:D
this is true, but unfortantly as you will know, the turbo relys on hot expanding gasses to operate efficiently not just gas velocity, so its a bad circle of ceramic death..lol
Just my 2c.
And how does one bond the ceramic to the shaft.. This is where the problem lies, its not a ceramic shaft.
I was under the impression that the wheel departed the shaft because of excessive heat, which causes the material that joints the ceramic wheel to the shaft to fail.
Not suggesting that I am right, but just what I have been told.
Beat me to it. Had to have a piss while typing my post.
Edited by 09ONE_32
this is half correct.
the reason is the wheel is pressed from the inside out by the shaft, and the material that bonds the wheel to the shaft weakens.
next time you flog the turbo, the wheel expands BEFORE the heat can transfer to the shaft and evenly heat the unit, causing the wheel to "fall off"
Are heat and rotating speed not related to each other?
no they aren't. boost pressure and heat are related. the higher the pressure, the higher the temp. you can increase airflow and have the same pressure and it won't raise the temp.
also having a restricting exhaust holds in the heat more. a more restricting exhaust has a higher pressure in it, which creates more heat.
At least you'll never have that problem with N1's!!
Interesting that nissan also had nylon compressor wheel and ceramic turbine wheel on the r34 GT-T.
nylon comp wheel was also for quicker spool but the main reason was for the bearings. a lighter rotating mass lightens the load on bearings, which stretched the service life!!!
:D
it was probably cheaper and lighter in wieght, which means faster response.
its like oem would be worried about how it went at 12psi for extended periods of time as this was beyond the factory scope/specs. sure they would have tried it for a few laughs, but its well within acceptable for factory configuration
One of the HPI dvds had their R34 GT-T project car blow one up on a track day but they were sort of expecting it to after all the mods they did. Was funny though.
On guy who lives near me has a NOS system on his GT-T and the stock turbo is still hanging in there.
    • Just don’t be silly enough to think it’ll never happen either
    • I take it that you bought the centre to suit the GTR axles? As in there was a plan, not just somehow lucky that it worked? It all looks excellent, by the way.
    • New engine block time. Up to you whether you want to keep going down this road with this project. Unfortunately a lot of these cars are like this. The road to getting these cars into decent shape is long and not fun for reasons that you're discovering.
    • Essay time. First things first, an RB running stock turbo and boost levels shouldn't get so bad as to stall from reversion if the recirc valve has been deleted. Should get a little fluffy and annoying, but in my experience, not so bad as to stall. Of course, every car is a bit different, so it remains possible that stalling will happen. So, running with no recirc valve is somewhat of an option, for otherwise stock stuff. Atmo BOVs cause all sorts of shit, even on an otherwise stock setup. Only gets worse the higher the boost and the bigger the turbo. At that point you really need to go for a different ECU and no AFM. Rebuilding the stock recirc valve configuration is not hard. You just need a stock or aftermarket BOV with the appropriate adapter for the 2 bolt flange on the back of the J pipe, and to get/make an appropriate ~1" pipe to get the air back to the turbo inlet, and to possibly modify the inlet (if it is not stock) to take the recirc pipe back in. Not hard. Just takes some cutting and welding. Putting an R35 type AFM into the car anywhere is not as simple as just buying the AFM and throwing it in. You will also need to buy the appropriate boss that will then need to be welded onto the pipe where you're installing it. You can clearly see why by looking at the photo posted above. They are not a "simple" swap for a stocker. You can't put on in place of the stock AFM. You can put one in place of the stock AFM, if you get the mounting boss and weld it to some pipe and otherwise make that pipe piece work like the stock AFM housing. Or you can buy such an adapter, either complete with the 4 bolt flange for the air box, or without, for varying degrees of work needed to then make it fit your stock airbox or some pod filter or whatever you have going on. Oh, and the R35 AFM is not plug and play. The wiring is different, but changing that is trivial. The plug is also different so you either end up repinning the original wires onto the new plug, or you just use a short adapter. If you weld a boss to the cold side pipe, the cold side pipe really wants to be 3", otherwise the scaling on the meter can get a bit weird, but whatever the pipe size, it's not as easy as just using the (fully documented in the Nistune doco) simple method for choosing R35 AFM in X" pipe size in the software, because the scaling will already be a bit different. Anyway, all of this has been comprehensively worked through on the Nistune forums, so there is full knowledge available. I would use a Link/Haltech before I would bother putting an AFM into a cold side pipe. That's a lot of effort for a bodge. Nistune is great, can work well even at fairly high power levels, but you are stuck with the limitations of it being the stock ECU, which includes needing to use an AFM, which is not always convenient for every set of modifications. You have to have a think about what you already have, what you want to have, and decide early if you'd be better off jumping ship to an aftermarket ECU. This so you don't waste time and money doing things 2 or 3 times. Never heard of ECUmaster. Sounds like a backyard operation. If there are good tuners for it where you are, and it is a solid product, then it will be fine. We're only talking about an R engine here. Back in the day they all ran on crude nasty early 90s ECUs and they were fine. You don't need a rocket surgeon's ECU to run one.
    • So left off with high hopes of having a gearbox in pretty quickly........ Got the adapter plate that week and had to chase a few threads and work out how/where everything goes as no instructions. Got the adapter fitted, test fitted gearbox and found had to cut and shave a few things. Tunnel required some hits with a decent hammer to give some clearance on passenger side but it fits with no problems,  could fit a 8hp70 with a little more work. For a cross member I wasn't going to spend $1100 on so shiny machined piece. Went through a few designs and remembered I had a gktech s chassis to cd00# cross member. Fitted that and found its close enough with a few extra bits welded so have gone that way and still a work in progress.  After this got into modifying the intercooler with some bends and clamps. I was procrastinating on this as was not keen to cut up and weld it myself but happy with the outcome.  Onto the radiator shroud and oil cooler mount. This thing took way longer than I thought it would but having to add an extra oil cooler for the trans and wanting everything within the chassis rails its good enough for now. It mounts to the chassis and gives plenty of room for lines and pipes. All the coolers are rubber mounted and sealed the shroud on the top and sides, will use some tape to seal the bottom gap of about 10mm. 20250508_111500.mp4   Next job was to build the new diff and after a delay with a friend got built this week. I ended up putting it all together with supervision and was good to learn how to set one up correctly. I ended up going a 3.69 ratio, nismo 1.5 way gt pro with gtr Axel's. Stripped it all down, gave all the parts a good clean, pressed on new bearings and set backlash. Was good working in a clean assembly room with all the gear. Once got home wire wheeled the case and hit it with some rollbar/chassis black paint. Got a few more bits done but will leave them for the next update.
