hey guys
just had a another question
with the stock ceramic turbos ive heard that its impossible to know when there gona blow up but it will happen
everyone sort of says its the heat that kills them
like if ya run a bar boost or new cams etc etc
i was thinking today that maybe its the oil lines clogging up over time and blocking
leaving no oil going to the turbs and then just burning away till a ceramic explosion
what do you guys think??
or am i just talking shit
g
https://www.sau.com.au/forums/topic/122901-ceramic-stockies/
  • Replies 64
Posted Images
if you could keep the exhaust wheel and shaftat an even say 25oC, the wheel would not explode.
if its pumping 15psi @150,000rpm for 30 seconds @ 1200oC it will die fast due to expansion
if its pumping 15psi @150,000rpm for 10min @ 10oC it will stay together as long as the temps are even, and consistent
A ceramic wheel or shaft should be more heat tolerant than a steel one. Cermic pieces are fired at over 1000*C, steel won't take that. I would think that it would be the pressure of the forces pushing a ceramic shaft at very high rpm that would cause ceramic to crack, where as a steel blade will be much more tolerant than these forces.
Just my 2c.
In short,
Aim to keep those EGT's down.
What raises EGT's one engineer may ask another?
Reduced Timing
Detonation
Lean mixtures
:D
this is true, but unfortantly as you will know, the turbo relys on hot expanding gasses to operate efficiently not just gas velocity, so its a bad circle of ceramic death..lol
Just my 2c.
And how does one bond the ceramic to the shaft.. This is where the problem lies, its not a ceramic shaft.
I was under the impression that the wheel departed the shaft because of excessive heat, which causes the material that joints the ceramic wheel to the shaft to fail.
Not suggesting that I am right, but just what I have been told.
Beat me to it. Had to have a piss while typing my post.
Edited by 09ONE_32
this is half correct.
the reason is the wheel is pressed from the inside out by the shaft, and the material that bonds the wheel to the shaft weakens.
next time you flog the turbo, the wheel expands BEFORE the heat can transfer to the shaft and evenly heat the unit, causing the wheel to "fall off"
Are heat and rotating speed not related to each other?
no they aren't. boost pressure and heat are related. the higher the pressure, the higher the temp. you can increase airflow and have the same pressure and it won't raise the temp.
also having a restricting exhaust holds in the heat more. a more restricting exhaust has a higher pressure in it, which creates more heat.
At least you'll never have that problem with N1's!!
Interesting that nissan also had nylon compressor wheel and ceramic turbine wheel on the r34 GT-T.
nylon comp wheel was also for quicker spool but the main reason was for the bearings. a lighter rotating mass lightens the load on bearings, which stretched the service life!!!
:D
it was probably cheaper and lighter in wieght, which means faster response.
its like oem would be worried about how it went at 12psi for extended periods of time as this was beyond the factory scope/specs. sure they would have tried it for a few laughs, but its well within acceptable for factory configuration
One of the HPI dvds had their R34 GT-T project car blow one up on a track day but they were sort of expecting it to after all the mods they did. Was funny though.
On guy who lives near me has a NOS system on his GT-T and the stock turbo is still hanging in there.
