Hi all, I have read thru this entire thread and it has some excellent content. Excellent work guys and thorough research. From the above I too have developed a question and that is:
"How do 1995 R33 GTR stocko's compare?"
They are a smaller turbine and hence should, as stated, cope with slightly higher (raised) rpm's than say, a GTST turbine of the same year.
I currently run a 3 inch system, although only from the CAT back (with hi-flow 3" cat). I have also taken out the restrictor after extensive discussions on here saying that it's OK to do so. A combination of the higher flowing exhaust and removal of restrictor have raised the boost up to around 13.5 to 14 pounds.
I always let engine warm up and warm down (with turbo timer) as I'm aware that it does a world of good for engine and turbos. So, in other words I'm giving the turbos time to cool down and contract SLOWLY which should somewhat make life easier on them.
However, what does concern me is track days. I've had one on stock boost, but my next one will be with the higher boost level. Will the smaller GTR stockies put up with extended thrashings? The track is Queensland Raceway, so for those who know it has the front long straight while the rest of it is a series of small squirts from corner to corner where your brakes and tires experience more wear than anything else haha!
Any advice would be much appreciated guys - thanks!!
Tom
i think and most would probably agree its suicide at 14psi on stock GTR turbos on a race track
youll last two laps id expect before the wheels fail then youll risk the motor too
if i was to track my GTST with stock turbo id run 10psi , i wouldnt trust 12psi on a track
so for GTR 14psi is suicide, i would try around 11psi at the most and see if its safe
  • Replies 64
Posted Images
Mine let go turning right at an intersection, coming onto boost (doubt it would get to 12psi in first gear at all, but it let go at about 5000rpm tops), so maybe 5psi??? R33 S2 Turbo on RB20det.
What about high temps + change in angular/rotational velocity? Shaft speed wouldn't have been high on mine.
Fixxxer
Hmm ok. Well, there seams to be a lot of people on various SAU threads who say it's ok, and then there are also the same number of people who say no. But, we do have one critical factor in this thread and that is that it's 14 pounds on the track. Now, for those of us who've taken our skylines (be it GTR or GTST) out on to the track all know that there's a big difference between flying around a circuit and giving it a little squirt on the highway or wherever.
1 warm up lap, 5 hot laps and then a cool down lap of hell! It really tests the cars that's for sure.
So you reckon I'd be better of sticking the boost restrictor bung back in just to be on the safe side? With the bung in there the GTR was running somewhere between 10.5 and 11 pounds stock standard.
I got a guy at work who wants some GTR stockies to bolt onto his L28 engine (Nissan 260Z) so I might just take it easy with these and instead by an upgrade turbo package. Aparantly there are a couple of good deals out there....or perhaps go for a set of N1's?
Paulr33....might have to discard that 1 Bar rule for Skylines when it comes to track work???
Guys, I've posted up a fresh post about my queries here. Paulr33, you're most likely right there but I just want to get some input from other GTR owners and hopefully get some ideas on what turbos to maybe upgrade too. I'm fearing that my GTR stockos are just no good for track use hey - how g*y is that!!!!!
Here's the link to new thread - it should get some hits very soon hopefully
http://www.skylinesaustralia.com/forums/R3...im-t228630.html
    • Yeah its very rare I randomly see one driving around or in traffic, only really see them at events now
    • did you go to the us gtr festival? any progress on getting the car back out and running?
    • I had some time over the last week  and decided to test if block filler will hold the blocks shape similar to a torque plate after the head has been removed. 1, 3 and 5 were measured at 9 points each before and after. MY goal was to see how much impact a torque plate has on the shape of the bore. The first set of measurements were taken with the main girdle and head off with no filler. The block was then filled with grout up to the water pump (half fill) and the girdle and head were torqued to spec. The block sat leveled for 7 days and was disassembled. The second set of measurements were then taken. Results are presented as the delta between the original and new value. All values in the PowerPoint are presented in inches because America. The largest changes were 0.0035 in or 0.0889 mm between cylinders 3 and 5. There may have been even greater changes if the block was filled to the top with grout. I hope this information is useful and I'm curious to hear what you guys think.       Notes: My block had the most wear in cylinders 3 and 4. Due to the amount of change in 3, I measured 2, 4 and 6 separately. 4 was also all over the place. 6 was similar to 1. They were not included to keep the test objective.
