hey guys,
i have this problem with my left suspension it sound like something is lose and going to fall apart i am hearing all these different stories of what it can be? i was thinking it might be worn bushes or is it something much bigger
Perhaps you should have a look around and see if anything is outta place, if you have no idea what your looking at then perhaps you should take it to a suspension mob and see if they can see anything outta place. The chances of someone going yeh this is your problem, just from a simple "my left suspension sounds like its going to fall apart" statement are pretty bloudy slim. You need to provide more accurate detail on what is it exactly your hearing, feeling, noticing while driving, be it accelerating, braking, reversing, cornering and what have you. Then maybe someone can throw a more accurate answer your way.
Apologies if my reply seemed rude, was not the intention :D
lol sorry
its got bilstein shocks and springs its pritty hard suspention, the car seams to handle the same and when taking corners it doesnt make any noise when reversing or anything like that the only time it makes noise is if i go over a hole on the road or if the raod is abit bumpy, i dont know how to decribe the sound it just sounds like something is lose i spoke to my mechanic today he recons the strut might be gone.
Funny that!, I am having the same shit problem... Ya hit a bump and its like a knocking or rattling noise and the rear end feels like its gonna slide out even though youre in a straight line. I had the standard shocker replaced and the noise is slowly coming back again as if the lowered spring is mashing the shocker. Let me know if ya get a solution!!! Cheers.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
