Hey guys my R32 has developed a little annoying problem, i am aware that the speedo is connected via a metal wire from behind the surround and there seems to be a clicking at least every second when i'm going down the freeway, usually doing over 110km/h it will just keep ticking. Has anyone else had this problem or knows how to fix it without ripping my whole dash apart? Also had a search couldn't find any perviously related topics. Any help would be appreciated :(
Cheers,
Rhys
Mine does the same, I just assummed it was my keys tapping, its rather irregular and I have a metal keyring... I might try holding onto my keys next time I hear it - and keep watching this thread :(
its actually part of a what is now defunct speed warning chime. they dont seem to last..
do a search for it and u'll find some info on it.
mine does the same, its dying, sounds like a cat being hit with baseball bat...(not really) but u get the idea... search function is your friend!
I found this info on another site. I haven't tried it yet.
http://www.skyline-nissan.net/home/p2_articleid/21/s//amp;
- Remove the plastic panels under the driver's side dashboard.
- Drop the steering column (using the height / reach adjustment)
- Remove the instrument cluster. The small aluminium box on a bracket behind the
cluster is the noisemaker. Be very careful with the speedo cable – there is a plastic
sleeve than is prone to splitting where the cable enters the back of the speedometer. It
can be fixed with some heat shrink tubing or at a pinch some PVC tape.
- Disconnect the spade terminal, and remove the dingdong box. Peace at last.
Hope this helps.
Cheers
  • 4 months later...
aha, just discovered this thread having been working on my r32 gtr.
since i bought her i've had this ticking noise behind or in the dash cluster. it sounds like, to me, a box full of cockroaches running around inside. the noise happens regardless of the speed at which i'm travelling.
having taken my dash apart, i am 90% sure it's the speedometer cable making the clicking noise because i can localise the sound to the cable when the dash is off. it's the only thing clicking. i do not think it is a speed limiter.
anyone else have this?
Edited by sigsputnik
Hope this helps.
Cheers
That will fix the ticking noise as it is the over 100kph speed chime thing....
in my case the ticking noise occurs regardless of the speed at which i'm going - usually much less than 100 kph...any ideas?
i would reckon that it is still the stupid little silver canister that is to blame.....
just rip out the dash and remove the little f*kker and that should fix it...
otherwise it will most probably be the speedo cable.
good luck :rofl:
  • 14 years later...
http://users.tpg.com.au/adslv24i/speedocable.jpg
trying to revive an old thread here.. I have a sound that comes intermittently from my r32 gtst dash (in winter only..) at driving speeds only. Makes a nightmare to try diagnose and it can only be described as a box full of cockroaches running around exactly as Sigsputnik has said. My overspeed chime seems to be working fine. Did you find out in the end what the problem was?
    • this thread delivers, once again Skyline owners, our cars spend more time off the road than on the road
    • Some of the stuff the PDR guys in the states pull is amazing too. Instead of drilling a hole. They crank some insane tension into it. I actually DIY built a pulling bar myself that I used to pull the Subarus front end out with. About an hour's work, a bit of 30mm *3mm shs, and a piece of 5mm thick plate. Worked great!   But I vote replace it with a GTR rad support. And not going to lie, I'll laugh if a GTR rad support doesn't fit a GTt...
    • Sorry, that was with regards to the rather pretzeled corner of the reo bar. It's in such a state over the years that drilling a hole is probably preferable to bothering to unbolt the thing
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
