No back to back testing... I was having a tune issue prior to installing it, and couldn't have been bothered fixing it, then tearing it all out and installing the new plenum and then re-wiring it all again.
I'm using the standard throttle body.
The seat of my pants estimate tells me that its about the same as stock, as far as overall performance goes. It does make the intercooler piping about 2.5 feet shorter tho compared to how it used to be, so the usual theory's about reduced lag are true not that i've noticed...
Col - check out these couple of different sites i found just then about front facing plenums:
http://www.skylinesdownunder.com/forums/sh...ead.php?t=50962
R.I.P.S Website: http://www.ripsltd.co.nz/performance/
Plazmaman Website: http://www.plazmaman.com.au/
what power were you making when u maxed out the GTR injectors?
No idea as i never did a dyno run. Until I am happy with the cars performance i didn't see the sense of paying for a dyno run to fine tune the top end and get a power figure. Plus there is remmoving the front drive shaft and all every time i do a run.
It would easily get sideways spinning all 4 wheels in second when going down an on ramp sweeper onto the highway at about 80k's tho, so thats got to be about 330hp or so at the wheels.
Edited by GTST4Newbie
hi all first time i have added a comment.i as well have one of those inlet manifolds but with the 80mm throttle body.just in the proccess of putting the car back together as it has been repainted from white to blue.
Edited by wiked1
Well I did my first drag event with my GTS4 last night. I managed 3 runs before I my fuel pump started causing eratic fuel flow (its screwed)...
My second run was the "cleanest" but would have been quicker if i'd shifted to 2nd quicker. It was a 13.826 at 116.97mph.
I launched at 6000 rpm, spinning all 4 wheels off the line. The car got traction in 1st and left the line so quick I wasn't ready to shift to second. I lost about a second there, and then had lag till it spooled in 2nd. The rest of the shifts were good.
I need more practice racing, but had fun anyway. I am told you can work out HP from the MPH and vehicle weight though I have no idea how. The car is stock weight and i'm 65kg. Can anyone do the math?
I was running 20lb boost, and reving to 7000-7500. GTR 440cc injectors, at 87% duty. The car was running a full interior with the spare wheel still installed.
i just got a reply from Stryder Performance.
to melbourne i was quoted 545US landed. bout 725AUD.
perhaps u got yours mixed up with the 550AUD landed price.. coz i cant see it costing 13US bucks to you in sydney even at 395US.
anyways.. not to worry.. not my point of my post.
did u have any other issues fitting it ...have u got any pics of the factory parts fitted back up asides from teh throttle body.
thanks
Matt
Nope, no other issues fitting it. The main problem was just the water plumbing that goes under the plenum.
Given the opportunity to re-install the plenum i'd have looked got a better place to install the temperature sensors too, though they are working fine where I installed them between the lower plenum water runner, and the front radiator hose section. I'll take a few more pictures if you need it.
  • 3 weeks later...
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
