Ok so im getting some DrifTas Polo tops embrioded up with our logo and driftas.com on the front.
Cost is $40 for any size polo in black or white. (S,M,L,XL,XXL)
Please let me know ASAP if your keen as i have to get the order off.
You can PM or email ben(at)driftas.com with your size, colour and choice and i will let you know bank details for payment.
Turn around time of these will be about 10days (depends on final numbers) so they will be ready before July 30.
Please help support Driftas so we can keep providing drift days for you all.
Cheers GMB & Bart
DrifTas
https://www.sau.com.au/forums/topic/122979-driftas-polos/
So how are the polo's coming along???
Hey mate
i was hoping to get them from the embroider late this week but they have a fair bit on at the moment (and when i got the quote it wasn't for 50 shirts :) ) but hopefully early next week.
I'll keep you all posted :)
GMB
https://www.sau.com.au/forums/topic/122979-driftas-polos/#findComment-2288954
hows the polo's benny?
need it as the one im wearing smells lol.
wish the wife would use that big white box thing in the laundry called a something machine?....right below the dryer thingy.
Still waiting on them chief, hopefully seem them by the end of the week.
I'll let you know when i get them though :D
And how come you never let us know you had a time machine in your laundry Benny :D
https://www.sau.com.au/forums/topic/122979-driftas-polos/#findComment-2302816
  • 3 weeks later...
Polo's have been picked up (still waiting on a couple though) please get intouch with me so you can organise to get yours.
Launie boys did you want to wait till next weekend to grab them while your down???
For anyone that hasn't paid please pay asap (PM for bank details) as Bart and i are out of pocket.
Cheers again to all for the support
Gmb & Bart
https://www.sau.com.au/forums/topic/122979-driftas-polos/#findComment-2342967
  • 1 month later...
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
