Hi guys,
I need to get a small piece of pre-resined carbon sheeting. It must be real carbon. dont want any coloured weave, just the regular black/grey weave is fine. Could possibly buy some weave then just do the layers and resin myself but i'd prefer pre-fab. It's just to fill a hole in the centre console and will then use it to mount some switches etc.
Any help pointing me in the right direction would be much appreciated.
Richard
  • Replies 46
Posted Images
We've got some... bought off a supplier in Brookvale. If you want I'll get you the supplier details, otherwise tell me what size you want and I'll see if I can find some offcuts.
exactly like that! only just black/grey CF instead of kevlar weave, and also half that size (replacing the 3 gauge cluster).
but i'll take kevlar weave in a pinch if someone had some lying around (hint paul!). :D
i left some at Croydon's...ill ring em and see if its still there...ok
i'm excited. i'm going to use that space to mount the defi link controller and the dirtgarage D1 edition awd switch. and maybe relocate the ultra speed meter there too.
If that falls through, try going to a boat building place, there are a few around that make the sydney to hobart boats... We used to get their 'offcuts' to make our body work for a little SAE car. Cant remember who we used last year but its worth a shot, not something that comes to mind at first though is it!!
Do you have an oven? remember the pre-preg stuff needs baking!!
thank mate, yep i do have an oven. but i think a flat sheet that has already been laid and coated wont need any more prep work. just drill my holes and bolt it in.
Ahh yep, sorry i didnt realise it was just going to be a flat sheet that you want.
Good luck with it, post pics for general interest when you are done?
I am about to go to CRD myself, been speaking with a bloke called Jim, i need a few things done to my car. Hopefully within the next few days, things keep getting put on hold for me. I just want my car fixed, running nicely and back on the road
thanks for the kind offer Aaron. I'm going to chase up a lead tomorrow morning, but if they haven't got what i need i may take you up on that. we have some resin left and i guess i could just buy some regular fibreglass weave to make it 1 layer CF, 2 layer fibre...
I will let you know :P
BB
i may have sum left over if you want it, its only thin tho (1mm) carbon weave , guess can glue it to 2mm perspex to make it thicker, so yeh let me know if you need it.
aaron
Hi Aaron, if BB doesn't need it, I will take it. I need to replace a gauge panel and a POD heat shield cover so 1mm would be perfect. What are the dimensions?
:P cheers :D
Biatch,
There's a place in the same complex as UAS that does custom carbon fibre work... They were working on this 100% carbon fibre body race car the last time I dropped by.
The guy is very eccentric, but he does amazing work. He made custom sized sheets for this exact application for me a few years ago... Very cheap too. From memory I got him to do 3 layers of carbon (ended up being about 3mm thick and BLOODY STRONG), and a gloss top coat in double-din size, and it cost me about $30-40.
Can't remember the shop number, but I think the guy's name was Alan. John will remember the guy if you ask him.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
